Old 01-08-2014, 05:46 PM   #1
haywood2121
haywood2121 is on a distinguished road
haywood2121's Avatar
Default Pressure Solenoid Again!?!? 2003 Saturn LS
I have a 2003 Saturn with 200k+miles.
Back in ~~ 2008 I had the transmission line pressure solenoid replace (the transmission was jerking and service wrench light would come on)
Fast Forward to 2013 and now I'm having the same issue.. BUT NOTHING ELSE..GREAT CAR!
Should I just replace the solenoid again?.....aren't the odds in my favor to just change the solenoid again?...Instead of paying a $90+ diagnostic fee.
Thanks for your help!
2003 Saturn LS3 260000 miles and still rolling
Add to haywood2121's Reputation
Rate the quality of this post and help haywood2121 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
haywood2121 is offline   Reply With Quote
Old 01-08-2014, 06:27 PM   #2
pierrot
pierrot's Avatar
Default Re: Pressure Solenoid Again!?!? 2003 Saturn LS
[/QUOTE]Yikes! That's really unfortunate. Was there anything which preceded this problem's recurrence? Is the problem ongoing at the moment or will it come and go?
When the symptoms you described happened in my car, the first occasion followed about a complete transmission drain at a Saturn dealership, 11 quarts. It was not immediate, however. It occurred some months later on three or four occasions and then stopped. It didn't show itself again for another four or five years until one particularly hot Spring day in 2010. The jerking problem hasn't surfaced since then.
321,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 01-08-2014, 07:08 PM   #3
haywood2121
okay this is the CRAZY PART.
It was happening all the time about 9 months ago...then I noticed a connection that was loose coming from ???? that was rubbing some metal on the frame.
It must of got loose when the front bumper came off
When I tie wrapped it so it wasn't rubbing anything it stopped for about 4 months.
Now it is back again steady for the last 2 months.
Old 01-08-2014, 09:53 PM   #4
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
2002 L-Series 3.0L Sedan
Sell since we have no driving history on the Saturn we can't speculate as what might be the cause. Could be the Solenoid was of bad quality or your been towing very heavy towing which could be the cause of the failure and or the tranx itself is in need of rebuild. So we need details on the history of the Saturn and Tranx and your driving habits that will tell how one maintains their Saturn.
Add to Russet's Reputation
Old 01-08-2014, 11:03 PM   #5
haywood2121, was the original error code found? With wiring found chafed, is it possible the same wiring is damaged and causing the same problem?
Old 01-09-2014, 01:22 AM   #6
satlite440
2001 SL2
qurry was the code you replacedthe line pressure cntrol solinoid for a p1811? also how many miles on the trans? ever had a fluid change.. if it;s a 4t65 they are susptable to eather theair intake sensor being grounded out or reading skewed..possably the wire you had fixed.. you have high mileage so bushing wear is leading to 1 of he cluches going over 0.65 seconds to compleate lock up.. you didn't say if the ses or wrench light is on again.. persoaly i would see if anyone you know has a code reader or ck your local auto parts stores some states and places read codes... or get it diage.. it's always cheaper that throwing parts at it...
Old 01-09-2014, 10:07 AM   #7
haywood2121
I have ~~ 100k MORE miles on it since I first changed the solenoid ... with a total of 220k
My driving habits are pretty laid back, I stay in Raleigh, NC with NO hills and I don't tow anything on car.
Yes, p1811 was one the original codes.
Where is the intake sensor located??????????
I will check that today and get the codes read (if it comes on).
Old 01-09-2014, 11:07 AM   #8
I think satlite440 is describing the external air temperature sensor probe mounted behind the front grille. Its used to display 'EXT'(ternal)/outside temperatures on the HVAC control panel.
Old 01-09-2014, 11:22 AM   #9
haywood2121
After my front bumper fail off I have been getting those 'EXT'(ternal)/outside temperatures codes.....going to the junk yard to get another to replace it.
Do you know where is the intake sensor located?
Old 01-09-2014, 01:39 PM   #10
We have the same car. Look thru the front bumper, right side to locate the ambient air temperature sensor.
2003 l300 v6 pressure control solenoid - please help tjcleer L-Series Tech 9 11-30-2018 09:53 AM
2003 Saturn L300 fuel pressure problem! Colton92 L-Series Tech 21 09-11-2016 01:27 PM
where is 00 LS2 trans. pressure solenoid? 00 SL2 L-Series Tech 7 12-18-2013 10:33 AM
SL2 where is transmission pressure solenoid??? 00 SL2 S-Series Tech 7 12-16-2013 11:58 AM
where to buy pressure control solenoid????? chips1 L-Series Tech 9 11-01-2011 07:24 PM
