Old 02-12-2003, 05:48 PM   #1
SpaceFrame
SpaceFrame is on a distinguished road
Question Faulty rear defrost switch? I don't think so now!
My rear defrost switch functions intermittently ... mainly, it works in warmer weather when I don't need it.
Anyway, figuring it was a bad switch, I went to the local Saturn dealer and purchased a replacement switch. $55 later, I have a shiny, new-looking switch but still no rear defrost.
Any ideas?
Add to SpaceFrame's Reputation
Rate the quality of this post and help SpaceFrame reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SpaceFrame is offline
Old 02-12-2003, 07:13 PM   #2
dancingator
dancingator is on a distinguished road
Default
A Chilton manual will have good electric diagrams to follow. Bennet Auto Supply or Barnes and Nobles. Maybe someplace online to.
Check out your owner's manual to determine which fuses and relays to swap out. Maybe that will help.
And check your connection at the rear window. Maybe its faulty.
Add to dancingator's Reputation
Rate the quality of this post and help dancingator reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dancingator is offline
Old 02-12-2003, 09:02 PM   #3
wolfman
wolfman's Avatar
Default
Actually the switches rarely fail...but then you know that now. Check the connections at the rear grid on either side of the rear window. You CAN safely unplug the slide on connectors if you are CAREFULL to check for corrosion. The other place to check is the chime module which also contains the timer for the rear defroster. It is a plastic box about the size of a deck of cards plugged into the BACK of the in car fuse box. Access it by popping off the cover on the DRIVER's side of the center console and then reaching through to the back of the fuse box from the driver's side.
Add to wolfman's Reputation
wolfman is offline
Old 02-12-2003, 09:27 PM   #4
sattech
sattech is on a distinguished road
Default
What year is the car? If '95 or later, When you depress the switch does it stay lit, or does it lite only while you have it depressed.
Do you hear a relay click when you turn the switch on?
~ If it worked before you messed with it, it must be something you did ~
Add to sattech's Reputation
Rate the quality of this post and help sattech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sattech is offline
Old 02-12-2003, 11:40 PM   #5
mtlmutt
mtlmutt is on a distinguished road
Default defrost diag
turn on the defroster, use a test light or a volt meter, on the drivers side of the glass you should have battery voltage, as you go down a line of the grid the volts will drop or the test light will get dimmer. If the rear glass is tinted yes you will have to go through the tint to get to the line. by the time you get to the pass. side the test light will not light up or the volts will be very low. that is normal. oh, not to scare you but if you knock off one of those little metal tabs that the wire plugs on, good luck, you have to try to SILVER solder them back on. Normaly we just have to replace the rear glass. $600.00
good luck.
Add to mtlmutt's Reputation
Rate the quality of this post and help mtlmutt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mtlmutt is offline
Faulty switch?? Timguy1008 L-Series Tech 1 02-26-2009 05:06 PM
Workaround fix for faulty ignition switch mjkiefer General Saturn Discussion 0 01-19-2009 06:00 PM
Faulty Door locks and Dimmer Switch ldawsonAura Aura General 3 06-01-2007 02:30 PM
rear defrost justin_zink S-Series Tech 2 01-08-2007 01:12 PM
Should the defrost switch light up on my '97? auxmike S-Series Tech 15 08-02-2003 07:43 PM
