Old 01-06-2011, 03:28 AM   #1
frankv569
frankv569 is on a distinguished road
Default vibration after changing engine mounts
I replaced 3 of the 4 engine mounts with Anchor brand mounts from Rockauto.com- the only one I have yet to change is the mount beneath the crank pulley.
My problem is that I am still getting a lot of vibration. It actually feels worse than when my oem (disintegrated) mounts were in place.
Is this expected? Normal?? Has anyone else had this happen?
frankv569 is offline   Reply With Quote
Old 01-06-2011, 03:52 AM   #2
Default Re: vibration after changing engine mounts
With that brand of mount, it's entirely expected (but NOT "normal"). We've determined that "Anchor" actually refers to their best use (well, if they were heavier...).
You need an OEM top mount, for starters. For the bottom left transmission mount, there's a photo laying around here somewhere, showing how a BRAND NEW Anchor mount was actually FLATTER (less "lift") than a sagged-out compressed end-of-its-life OEM mount.
The struts ("dog-bones") aren't as critical to ride quality, but the Anchor brand are known to break. One semi-cheap option is to find a couple of dog-bones from a '98-up (or is it '99-up?) car, with the latest design, and replace the rubber inserts with Prothane urethane inserts, available online and from Summit Racing (and SDA, if memory serves). Makes the ride a little harsh, however.
Old 01-06-2011, 10:23 AM   #3
The 3rd design torque axis struts (dog bones) were fitted on late production 97 model year cars. And probably on all of the 98s. the life of the trans and top mount are extended greatly bey using the polly inserts in the dogbones. But if you are expecting the same level of performance/smoothness that is obtained with a 4 cylinder engine that has a dynamic balance shaft you are dreaming.
Old 01-06-2011, 10:28 AM   #4
After you replaced the top mount, did you loosen the two bolts for the one below the crank pulley and retorque them?
Old 01-06-2011, 01:10 PM   #5
SLCraig
Funny you mention this because it is incredibly obvious when I drive the 96 and then the 00, the difference in engine smoothness. The 2000 runs like a top. The 96 runs smooth looking as well from standing at the front end, but the minute you get in the car and start driving it is just not as smooth as 3rd generation's DOHC engine. If the clutch in the 3rd gen was better it would be an ideal car. I guess I'll have to change that down the road!
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Old 01-06-2011, 01:20 PM   #6
Disophisis
Disophisis is on a distinguished road
Disophisis's Avatar
I replaced my top mount on my 93 with an Anchor brand mount something like a year and a half ago, I think. It's been doing pretty well. The motor actually had to be raised a bit with the new mount because the old one was sagging so badly.
Just thought I'd give my experience, which has been ok. the car rumbles a bit but it's a 93 saturn, so I think some is normal at least. It is better than with the previous mount though.
1993 SC2, 5sp, 144,000 miles
Disophisis is offline   Reply With Quote
Old 01-07-2011, 08:36 PM   #7
jgcox6
jgcox6 is on a distinguished road
just changed all my mounts out...the top was OEM, the transmission mount is also OEM..AFTER I tried to cheap out on the transmission mount! The mount from NAPA was just a crappy as the other ones listed above. Lesson learned...ONLY USE OEM MOUNTS...especially the top and transmission.
jgcox6 is offline   Reply With Quote
Old 01-07-2011, 09:26 PM   #8
LTond56
LTond56 is on a distinguished road
Just installed a non-frowny upper mount on a friends SL.
She wanted it done right away as the current frowny mount was totally collapsed and her windows and doors were buzzing like crazy.
I stopped in at Pep Boys and was surprised to find they were selling non-frowny versions that are OEM look alikes.
No vibration and very smooth.
Hope it lasts!
LTond56 is offline   Reply With Quote
Old 01-08-2011, 02:43 PM   #9
oakraiders24
oakraiders24 is on a distinguished road
The one I got from Autozone was also non-frowny, and seemed very solid in its make. After installing, night and day difference.
oakraiders24 is offline   Reply With Quote
Bad vibration, definitely not the mounts Blackaddr S-Series Tech 11 11-16-2009 10:29 AM
New Engine/Trans Mounts - still got vibration hydromech S-Series Tech 5 11-01-2009 01:29 PM
TSB Transmission Mounts? Vibration? HELP verucalise Vue Tech 0 10-27-2008 09:15 AM
Heavy engine vibration, checked motor mounts dgreen97 S-Series Tech 2 10-16-2008 12:47 AM
Lower mounts need changing? joshjani S-Series Tech 11 03-15-2005 08:07 AM
