Old 05-24-2010, 08:24 AM   #1
kbg1
kbg1 is on a distinguished road
2008 Astra XE
2003 ION-2 Sedan
Sad Help With intermediate Steering Shaft
hi
is there an aftermarket part to replace the gm intermediate shaft in an ion?if so where can they be purchased?
will a cobalt or g5/pursuit one work?
can someone provide the proper gm part# for the intermediate shaft for a 2003 ion2 manual/2.2L?
would it be worth getting a used one from scrap yard and how hard are they to remove?
thanks,jeff
Add to kbg1's Reputation
Rate the quality of this post and help kbg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kbg1 is offline   Reply With Quote
Old 05-24-2010, 11:29 AM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Help With intermediate Steering Shaft
this part wears out, almost always, so get a new one. as far as a part number, call your local friendly saturn dealership and they will give you one.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 05-24-2010, 01:21 PM   #3
kbg1
2008 Astra XE
2003 ION-2 Sedan
saturn gone in canada.
new shaft here is $289. at the gm dealer.
they would not give me the part# ,only tell me that the p/n i had was wrong and for a aura.
i am trying to get one off ebay and need to know if any other gm cars have the same part#
thanks,jeff
Old 05-24-2010, 01:25 PM   #4
2006 ion2
2007 ION-2 Sedan
the ion is unique in many ways, I do believe this is one of them. a good dealership (GM or not) will give you the P/N and will cross check it with the cobalt P/N
2007 Saturn Ion 2
Old 05-29-2010, 06:14 PM   #5
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
I believe you can order this part at www.saturnparts.net
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
Add to rickystarshine's Reputation
Rate the quality of this post and help rickystarshine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickystarshine is offline   Reply With Quote
Old 06-08-2010, 08:55 AM   #6
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
the cobalt and the Ion are the same with this part.
Add to chilipepper1327's Reputation
Rate the quality of this post and help chilipepper1327 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
chilipepper1327 is offline   Reply With Quote
Old 06-08-2010, 09:48 AM   #7
kbg1
2008 Astra XE
2003 ION-2 Sedan
the part# are not the same,this is from a tsb:
15800140 Shaft, Intermediate Steering (Cobalt/G5/Pursuit)
15799676 Shaft, Intermediate Steering (ION)
22730246 Shaft, Intermediate Steering (HHR)
Old 06-15-2010, 09:49 AM   #8
chilipepper1327
My bad, sorry about that. That is what happens when you listen to someone you believe is right. Like the Saab parts dept. Oh well
Old 02-16-2011, 10:04 PM   #9
kbg1
2008 Astra XE
2003 ION-2 Sedan
thread ressurection
i finally got one off ebay with the correct part number.almost a year looking.
does anyone know how long this should take to replace?
my local mechanic says 2.5 hrs.
also a new steering problem hopefully related to the shaft also,now in cold weather the steering whines(or squeaks) when turning the wheel,could this be from the bad shaft also?
thanks,jeff
Old 02-16-2011, 10:14 PM   #10
cardude427
cardude427 is on a distinguished road
thread ressurection
thanks,jeff
It took you a year to find it? you could have gone to canadian tire and gotten one. Its stocked at any reputable parts store, I can get it for like $80, its no expensive.
You can do it yourself but you cannot let the steering wheel move. I did it in my dads '05 malibu maxx, once you take out shaft the wheel can free spin and if it does your looking at major $$$ in fixing. So have a buddy hold it still.
Add to cardude427's Reputation
Rate the quality of this post and help cardude427 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cardude427 is offline   Reply With Quote
Old 02-16-2011, 10:26 PM   #11
kbg1
2008 Astra XE
2003 ION-2 Sedan
the intermediate steering shaft is a gm only part with no cross reference.
cobalt/g5/pursuits are all different!!!
give me a canadian tire p/n for this(you cannot)
Old 02-16-2011, 10:41 PM   #12
MoparNut
MoparNut will become famous soon enough
MoparNut's Avatar
2.5 hrs?!? Umm, no. It pays 0.5 hours warranty time and takes about 15 minutes with a lift, figure if you do it yourself on jackstands a half-hour at most.
I mark the position of the input shaft on the rack relative to the seal with a black Sharpie with the steering wheel dead-centered before loosening anything. Then when I put the new shaft in I can set the rack in exactly the same position as before. Then set the steering wheel perfectly straight and slide the shaft onto the splines as close to that position as possible. If it goes off a bit you can undo the shaft at the column and move it 1 spline either way until perfect. The reason I mark it at the rack is that the new shaft is rarely clocked exactly the same as the old and you will get a crooked wheel if you mark the splines on the column and align the new shaft to that mark. Good luck.
Add to MoparNut's Reputation
Rate the quality of this post and help MoparNut reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MoparNut is offline   Reply With Quote
Old 02-16-2011, 11:13 PM   #13
2006 ion2
2007 ION-2 Sedan
thread ressurection
thanks,jeff
it shouldn't have taken a year. any chevy/ prior saturn dealership should stock this part,or at the very least could have one within a week.
2007 Saturn Ion 2
Old 02-17-2011, 11:32 AM   #14
chilipepper1327
All you have to do is mark it before you remvoe it. then you don't have to worry about it moving. Very simple and solve big headaches
Old 02-18-2011, 12:15 AM   #15
SaturnIONSLVUE
SaturnIONSLVUE is on a distinguished road
2007 ION-2 Sedan
I am waiting 6 months for parts at my Jeep dealer for my jeep and the parts are still not in.
I am not going to replace my shaft again when it starts making noise it is just a waste of money. MY 2001 GMC Jimmy had the same problem.
Add to SaturnIONSLVUE's Reputation
Rate the quality of this post and help SaturnIONSLVUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnIONSLVUE is offline   Reply With Quote
Old 02-19-2011, 08:26 PM   #16
cardude427
Its not the positioning, its whats inside the column and wheel, theres something (clock spring?) its what connects the air bag too the electrical system, if the wheel free spins while you have everything disconnected the spring will snap and its expensive to fix and you wont be able to drive until its fixed.
@ kbg1, okay well ill test it out when i replace mine in a couple months but how come you didnt walk into a GM dealer and ask for the part?
Old 02-19-2011, 08:43 PM   #17
2006 ion2
2007 ION-2 Sedan
you are correct, broken clock spring = dead car.
2007 Saturn Ion 2
Old 02-22-2011, 09:38 PM   #18
MoparNut
MoparNut's Avatar
True, you should be careful not to spin the wheel freely, but it really doesn't move much at all with the shaft disconnected. If you are worried about it, simply use a steering wheel lock or a seatbelt to keep the steering wheel immobilized.
Old 02-22-2011, 09:54 PM   #19
kbg1
2008 Astra XE
2003 ION-2 Sedan
i was quoted $229+tax at gm
saw cobalt/pursuit/g5(all wrong p/n) on ebay for less than $100
waited and got proper ion p/n for $40 canadian brand new
jeff
intermediate steering shaft MsFordJustice Vue Tech 4 06-15-2013 03:19 PM
Intermediate Steering Shaft replaced, again. AuraDrvr89 Aura General 11 11-23-2012 04:09 PM
intermediate steering shaft ring? beensmoked L-Series General 5 09-26-2006 05:08 PM
Intermediate Steering Shaft Boot sstar L-Series Tech 2 03-24-2005 01:14 PM
Intermediate steering shaft? IceMan2 Miscellaneous Tech 0 08-25-2002 10:44 PM
