Old 10-31-2009, 11:49 AM   #1
hydromech
hydromech is on a distinguished road
hydromech's Avatar
Default New Engine/Trans Mounts - still got vibration
I recently replaced Lower Engine mount (right) and Lower Trans mount (left). Both were loose and the Engine mount was nearly broken… I used "ANCOR" mounts from Advance Auto Parts - Saturn original was too expensive
Now all mount are strong but I'm getting vibration: panels, doors etc…
Advise needed: what can I do to eliminate that vibration ?
2000 Saturn SL1, SOHC, Automatic, 189K
Add to hydromech's Reputation
Rate the quality of this post and help hydromech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hydromech is offline   Reply With Quote
Old 10-31-2009, 02:21 PM   #2
amites
amites is on a distinguished road
1997 SW2
Default Re: New Engine/Trans Mounts - still got vibration
how's the engine sound?
if it's running rough replacing mounts aren't going to help
if this is a new issue then I think it's beyond my realm of experience
Add to amites's Reputation
Rate the quality of this post and help amites reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
amites is offline   Reply With Quote
Old 10-31-2009, 02:49 PM   #3
hydromech
hydromech's Avatar
Engine is running smooth... The vibration happens around 1800 RPM
Old 10-31-2009, 04:55 PM   #4
SLCraig
Last mount is the trans mount, underneath the trans, basically right below the dogbone on the drivers side. Check to see how that one is holding up. Aside from that, if its fine... I don't know why else you'd be getting a vibration, unless you're used to expensive cars that are dead quiet and smooth at all times... haha.. It is afterall, a Saturn.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-31-2009, 08:00 PM   #5
off-track
off-track's Avatar
I recently replaced Lower Engine mount (right) and Lower Trans mount (left). Both were loose and the Engine mount was nearly brokenů I used "ANCOR" mounts from Advance Auto Parts - Saturn original was too expensive
I believe it's Anchor.. and, that's very likely the problem (specifically the upper mount= "frowny"). Yes, the Saturn one is more but, most everyone has reported problems with the aftermarket Anchor mount. Seems to range from the problem you report to working fine but failing again in a year or two. I'd take it back and cough up the difference for OEM.
SLCraig.. note he did replace the trans mount as well. .. Oh, wait a minute! Mount problems usually exhibit mostly at idle. Hmm, "@ 1800" only, any gear, under load or just cruising and, most importantly, not so much at idle?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 11-01-2009, 01:29 PM   #6
SLCraig
I agree about the issues with the Anchor top mount. I bought one for my SL1 back in the day, typical frowny junk, I ended up getting a mint OEM style mount from a wrecked car at the junkyard, unknown mileage, and installed it in place of the anchor. Incredible difference. Biggest time I notice the difference is at low RPM take offs, the old mount would chatter the engine, and the car would shake, and now its just smooth even when the RPMs dip down (5 speed) The OEM mounts really are better. I can't comment on the dogbones, I've yet to replace them.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
Bad vibration, definitely not the mounts Blackaddr S-Series Tech 11 11-16-2009 10:29 AM
Heavy engine vibration, checked motor mounts dgreen97 S-Series Tech 2 10-16-2008 12:47 AM
Replacing Engine/Trans.Mounts quickster S-Series Tech 64 06-01-2008 09:10 PM
part number for trans/engine dogbone mounts dmc S-Series Tech 2 12-03-2006 11:00 AM
4 Engine/Trans Mounts?..... gm7 Miscellaneous Tech 9 05-01-2004 08:11 PM
