Go Back   SaturnFans.com Forums > Models > Saturn Sky > Sky General
View Poll Results: Which car does the SKY most resemble?
SEAT Tango 13 46.43%
BMW Z3 3 10.71%
AUDI TT 11 39.29%
An old MG 1 3.57%
Multiple Choice Poll. Voters: 28. You may not vote on this poll
Closed Thread
Old 02-14-2002, 04:28 PM   #1
Plastic Gravity
Guest
Posts: n/a
Default Seperated at Birth? (SKY)
Everyone's seen the SKY in some form or another by now...and the consensus seems to be that the car is decidely AUDI TT'esque in shape and appearance. Well, I won't deny that, but check out this car....and tell me it doesn't look even MORE like the SKY or vice versa. Note the GRILL, the BADGE, and the split intakes in the nose...man, that's freaky.
SEAT Tango
Saturn SKY
Audi TT
I like the SEAT's expressive nose much better than the SKY. The side of the SEAT has that same clean with 1 curve theme that the SKY uses. The elements are all the same, the execution is much different. The SKY uses sculpted primitives, the SEAT uses compound curves. The rear cowling on the SEAT goes a little crazy, overall I like it better than the SKY.
Of the three, the AUDI is still the best looking. What do you think?
Add to Plastic Gravity's Reputation
Rate the quality of this post and help Plastic Gravity reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-14-2002, 04:59 PM   #2
Phil
Phil is on a distinguished road
Default
Like the TT? Sorry, the SKY doesn't have anywhere near that much style and panache.
The Z3? No- the Z3 looks muscular.
An MG? Too big. For that, you should be able to put the SKY in a matchbox without removing the matches first (not that we wouldn't enjoy a small car like that...).
The SEAT? Let me put it this way...
It ain't no coincidence Saturn, SKY, and SEAT all begin with "S". Somebody went ripping off designs.
Add to Phil's Reputation
Rate the quality of this post and help Phil reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phil is offline
Old 02-14-2002, 08:29 PM   #3
Bar(long a)
Bar(long a) is on a distinguished road
Default
Definitely closer to the TT.
However, the production model will probably have a different nose as the engine/ chasis integration for production v. concept are quite varying due to cost constraints. Cost will be the determining factor in trying to keep it under $18k.
Add to Bar(long a)'s Reputation
Rate the quality of this post and help Bar(long a) reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bar(long a) is offline
Old 02-15-2002, 04:04 PM   #4
Qlara
Qlara is on a distinguished road
Qlara's Avatar
Dizzy
Trouble is the SKY's square holely-grille looks so ugly and untouch. The SEAT has a subtle roundness with well-balance in chrome edge. Some work is still needed to be done in SKY's unfinished 'Hole' before it can go into production....not just like that! :o:
Add to Qlara's Reputation
Rate the quality of this post and help Qlara reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Qlara is offline
Old 03-13-2002, 08:28 PM   #5
GR898SL2
GR898SL2 will become famous soon enoughGR898SL2 will become famous soon enough
GR898SL2's Avatar
Dizzy
The SKY roadster's snout looks, well, unfinished, as if someone just cut out a square patch from the front end and stuck a Saturn logo in dead center. Cheeeesy!!! Hopefully that front grill won't be approved for production, but with Saturn, you never know!
Add to GR898SL2's Reputation
Rate the quality of this post and help GR898SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GR898SL2 is offline
Old 03-13-2002, 09:14 PM   #6
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
Default
Looks like a modified SEAT, but both draw cues from the (much more blander) audi TT.
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Closed Thread
Flashback Friday: When GM Gave Birth to Saturn Charlie General Saturn Discussion 12 02-15-2010 07:42 AM
GM Delta Plant - Birth of the OUTLOOK Outlook IL Outlook General 2 03-13-2007 05:36 AM
Saturn History(The Birth of Saturn) Euphony010 General Saturn Discussion 11 10-16-2004 04:09 AM
Seperated Wheel Bearing Dipsetct22 S-Series General 12 07-06-2004 07:05 PM
