Old 01-31-2009, 09:27 AM   #1
scottb022563
scottb022563 is on a distinguished road
Default 1998 SL2 intermittent starting issue
I have a 1998 SL2 134K miles. On occasion after I have been driving for a while the car will not start up after turning the ignition off. It sounds like it is not getting any fuel. Then in about 10-30 minutes it will start fine. It runs normally once it has started. As mentioned this occurs intermittently. Do you think it is the fuel pump or fuel filter? Any tips to diagnose this issue?
Also I went to Autozone and they said my fuel filter never needs replacement but I have seen richpin's video on how to replace. Any thoughts on why AZ's computer says the fuel filter never needs replacement. Thanks
Scott
Add to scottb022563's Reputation
Rate the quality of this post and help scottb022563 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
scottb022563 is offline   Reply With Quote
Old 01-31-2009, 10:43 AM   #2
Default Re: 1998 SL2 intermittent starting issue
The service schedule in your owner's manual is more accurate and complete than anything they have at Autozone. Your car's fuel filter should be replaced every 100,000 miles.
As for the no-start, you should first determine whether it's spark or fuel (or something else) that's causing it.
Add to madpogue's Reputation
Old 01-31-2009, 12:28 PM   #3
scottb022563
Thanks for the reply. It sounds reasonable about the fuel filter replacement.
regarding spark or fuel as the cause for not starting. How could the spark be intermittent? I can see if the filter or pump is going bad. Thanks again.
Scott
Old 01-31-2009, 01:51 PM   #4
Common no-spark issue with our cars: the crankshaft position sensor (CPS) fails as the engine gets hot. When it cools, it works again.
Quick & dirty spark test - remove the #1 and #4 spark plug wires from the coil they share. Observe as an assitant turns the key to START. You should see spark jumping between the coil tower. 'Course, the test is only relevant during the no-start episode.
Old 01-31-2009, 06:06 PM   #5
The 98's had a thing for intermittant crank position sensors. As madpogue said test for spark when the car dies and will not start. No spark replace the crank sensor.
Add to ssicarman's Reputation
Old 01-31-2009, 07:36 PM   #6
scottb022563
thanks so much for the info, you all rock. I will test it out during the next failure.
Scott
Old 02-03-2009, 12:24 PM   #7
scottb022563
I replaced the crankshaft position sensor and all seems well. Thanks!
Scott
a video by richpin
http://www.youtube.com/watch?v=QKb_TTQo0J4
1998 SL2 Starting woes mokurai S-Series Tech 10 10-01-2008 11:55 PM
1998 sl2 starting problem shutterbiker S-Series Tech 11 09-10-2008 07:10 AM
1998 SL2 Starting Problems Naleya S-Series Tech 4 02-25-2008 08:31 AM
1998 SL2 Not Starting All The Time adirondackice S-Series Tech 3 01-25-2007 08:02 PM
1998 SL2 auto slips when starting in D wreckhog S-Series Tech 6 02-21-2006 01:40 PM
