Old 11-12-2016, 03:51 PM   #1
C152
C152 is on a distinguished road
C152's Avatar
2008 Astra XE
Default Reverse in cold weather - manual transmission
Hi all,
On a cold -20 C morning last winter something odd happened after backing out of my parking spot, I could not shift into first gear because the little button on the shifter remained in the engage reverse position. After a few seconds it lazily snapped out. This is not a problem if the cabin has warmed up. Similar foible with my glove box, don't open it on a cold day, it won't close.
Has anyone else had this problem? Any suggestions? Should I get one of those hand warmers for my shifter?
Kind Regards,
C152
2008 Saturn 5dr XE (Opelized) Astra
2008 Saturn 3dr XR (to be Opelized) - OK, it's my daughter's
Add to C152's Reputation
Rate the quality of this post and help C152 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
C152 is offline   Reply With Quote
Old 11-12-2016, 05:11 PM   #2
Action Jackson
Action Jackson is on a distinguished road
Action Jackson's Avatar
2008 Astra XR
Default Re: Reverse in cold weather - manual transmission
Maybe the button/switch is caught on something?
There's a youtube video showing how to change the shiftknob on these cars. Probably wouldn't hurt to check yours out.
I've taken mine apart to have a look at.
2016 Honda Fit EX CVT
2008 Saturn Astra XR 5spd (traded)
2000 Acura Integra GS 5spd (SOLD)
2003 Mazda Protege5 5spd (RIP)
Add to Action Jackson's Reputation
Rate the quality of this post and help Action Jackson reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Action Jackson is offline   Reply With Quote
Old 11-12-2016, 05:30 PM   #3
Presuming this is a sticking linkage in sub freezing temps, would a good quality silicone lube in spray work to keep linkages moving? An alternative would be lithium grease.
Old 11-16-2016, 09:57 PM   #4
C152
C152's Avatar
2008 Astra XE
Thank you both.
Kind Regards,
C152
Old 11-17-2016, 11:10 AM   #5
tackepj
tackepj's Avatar
2008 Astra XE
I've definitely had it happen to the glove box latch in cold weather, but not the gearshift, although it's like stirring molasses at those temps. It'll still let you select 1st, right? It just wouldn't prevent you from going into R accidentally?
Current: 2008 Astra XE
Add to tackepj's Reputation
Rate the quality of this post and help tackepj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-17-2016, 11:06 PM   #6
C152
C152's Avatar
2008 Astra XE
Hi tackepj,
Nope, to the best of my knowledge, it can only go into reverse until the button snaps out.
Kind Regards,
C152
Old 11-22-2016, 12:35 PM   #7
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
I've never had it keep me from going into first, but I've had the button stick and make it hard to find first gear. I've never been able to find what is binding, but I got in the habit of just hitting the shifter against the spot below 5th gear when I shift out of reverse, and it always pops the reverse lockout button back into place.
Drives: 2014 Volt, 2017 Acadia
Past Cars: 08 Astra, 15 Acadia, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 01-27-2017, 02:37 AM   #8
Brianvande
Brianvande is on a distinguished road
Brianvande's Avatar
2008 Astra XR
Originally Posted by C152 View Post
Hi all,
I have this problem constantly. What I do is bring it back into neutral after reversing, and wiggle the stick back and forth quickly until the reverse button snaps back down.
2008 Saturn Astra XR3 5-Speed
Add to Brianvande's Reputation
Rate the quality of this post and help Brianvande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brianvande is offline   Reply With Quote
Old 01-27-2017, 08:29 PM   #9
kikastra
kikastra has a spectacular aura aboutkikastra has a spectacular aura aboutkikastra has a spectacular aura about
kikastra's Avatar
2009 Astra XR
I have noticed this or what I believe to be this only this year after a recent -20 cold snap. I would back out of my driveway, then go to put it into first (figuring since I let go of the button, and brought it down to neutral, straight up should be first right?) only to be surprised that releasing the clutch gets me going in reverse again. But the second time going back into first always seemed to work. I'll keep a closer eye on it next time it gets cold to see if its the button sticking.
Add to kikastra's Reputation
Rate the quality of this post and help kikastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kikastra is offline   Reply With Quote
Old 02-02-2017, 05:35 PM   #10
FieroAlex
FieroAlex is on a distinguished road
2008 Astra XR
Ours has started doing it this winter and we also jiggle the shifter in neutral to get the button to pop back out. It's annoying. Sometimes she's hard to put into first gear too so I'll probably look at replacing the shift linkage in the spring. Hopefully it's not too much of a PITA or expensive.
Add to FieroAlex's Reputation
Rate the quality of this post and help FieroAlex reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FieroAlex is offline   Reply With Quote
Old 02-02-2017, 08:23 PM   #11
Just a little FYI - My sister's Nissan Sentra auto shift lever would stick sometimes in winter cold. Without dismantling anything, it was determined the linkages or spring loaded detents and pushbutton were probably sticking in freezing weather. Someone, maybe me (don't recall) simply tried some WD40 in the plastic gaps where the mechanical button hangs up and other areas (possibly lifting up the boot cover and spraying WD40 on linkages). No more sticking in freezing weather. Sticking occurred after a few years of ownership but went away after some well placed lube allowed this sticking to go away.
Old 02-10-2017, 11:41 AM   #12
kikastra
kikastra's Avatar
2009 Astra XR
It happened to me again yesterday, and I can say for certain that that something is sticking. What I noticed is that if I pull the stick back from reverse and let go of the stick as it hits the neutral point, the button does not release and the shifter stays to the absolute left in the neutral zone. In warm weather or when the vehicle is warmer, the same procedure would automatically release the button, and the stick will move slightly to the right. In the cold weather, when it stays to the left, a slight nudge to the right will release the button and allow the shifter to go to first. So is it the button that sticks or is it whatever linkage or mechanism that allows the shifter to pop to the right that sticks (if there is such a thing)?
Old 02-10-2017, 04:36 PM   #13
I'm guessing it's the linkage under the boot. You can always try some WD40 behind the button first and see if it works otherwise the boot may have to be lifted to examine linkages for lubing with a light lithium grease. I don't have drawings for this xmission selector otherwise I would be certain where lube can work.
Old 02-24-2017, 11:15 AM   #14
David R
David R is on a distinguished road
2009 Astra XE
I did a little research into this as my manual does this when ever the temperature goes below about +2C. Getting progressively worse as the temperature drops. Tried WD40 in what I thought were key locations, had an effect, but not enough. At moderately cold temperatures popping or snapping the trigger un-sticks it.
Went as far as researching changing out the shifter. That's not happening. A lot of fussy work, and from the looks of things a real PIA if you want to do it right.
The fix from else where on these forums (non-fix really more of a work around) is, clutch-in, shifter out of reverse and straight across to 5 gear and a light smack against the far side. Works every time, even at -15C. Makes a real pop.
~I'm not an authority on anything~
2009 Astra XE 5sp 175K km
2000 Honda Civic SI 5sp 172K km, AKA EX Coupe - Gone
1997 SW2 DOHC Auto 325K km - Stored for winter, used in summer
Add to David R's Reputation
Rate the quality of this post and help David R reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
David R is offline   Reply With Quote
Old 02-24-2017, 10:04 PM   #15
JFS
JFS's Avatar
2008 Astra XR
Hello David R.,
~I'm ALSO not an authority on anything~
But I have played one at a bar after having a few.
Anyway, this is an interesting video of a product I am considering installing. I like the idea of a lighted stick shift. As it happens, the layer of display on mine is delaminating and starting to cut me if I am not careful.
An interesting thing to note is the large amount of lithium or other type grease one sees on the stickshift this fellow removes in the instructions on how to dismantle and then replace the OEM with this item. Looks like someone in a cold German winter must have needed to keep things well lubricated. I had the opportunity to have a look under at an Astra in a parts depot, and there was not anything like this amount of lubrication under the boot.
https://www.youtube.com/watch?v=WMZvJQ26ArM
Add to JFS's Reputation
Rate the quality of this post and help JFS reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JFS is online now   Reply With Quote
Old 02-25-2017, 11:42 AM   #16
David R
2009 Astra XE
Ha, I remember that video. I usually stopped at just around were he started doing the wiring. It was the cut and screw business that kind of turned me off. I have enough chewing gum and rubber bands in my life.
Yes the chrome lamentation is peeling off my shifter as well. Have a nice edge coming up, so far not a health hazard. Probably will be fine if I don't start picking at it.
Funny I'd never noticed all the lithium grease until you mentioned it. I'll add this to my to-do list for when the weather is warmer.
Old 02-25-2017, 01:05 PM   #17
emg77
emg77's Avatar
2008 Astra XR
Originally Posted by JFS View Post
Hello David R.,
Oh, this video is going to be handy. I noticed my shift boot has worn a hole in it after 114,000 miles of stick shifting goodness, so I bought a new leather set of boots online and they arrived this week. I hadn't yet researched how to actually get the shifter off to replace the boot. Now I know. Thanks!
Help! No reverse - Manual transmission juice91si Astra Tech 1 06-26-2015 09:35 PM
2004 Vue Manual Tran Shuddering on Cold Start in Cold Weather sixstringmonk Vue Tech 5 02-20-2012 07:28 PM
Reverse Problems with MANUAL Transmission Ramics S-Series Tech 4 02-17-2012 04:13 PM
VTI transmission in cold weather Brad LeBosse General Saturn Discussion 2 12-20-2004 02:14 PM
Manual Transmision in really cold weather jthj S-Series Tech 11 01-30-2004 04:50 PM
