Old 10-15-2019, 12:51 PM   #21
dakota1820
dakota1820 will become famous soon enough
Default Re: Manual trans and synchronizer questions
Right.... But my point is a lot of other transmissions have this as well and do fine with various products.
You yourself said some synchromesh fluids are fine in our transmissions.
Add to dakota1820's Reputation
Rate the quality of this post and help dakota1820 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dakota1820 is offline   Reply With Quote
Old 10-15-2019, 03:03 PM   #22
Proper operation in say a Chevy manual trans that requires GM Synchromesh fluid means absolutely noting in regards to a Saturn transmission.
Old 10-15-2019, 07:07 PM   #23
dakota1820
Let me be clear. Most modern transmissions use fiber/ composite materials on the synchros they very often times use a synchromesh or a gl4 rated lube.
ATF was a cheap solution that was adequate at best from day one.
ATF doesn't have the awp of a dedicated manual transmission fluid. .the only concern should be viscosity, which a premium synchromesh that is synthetic should negate the potential concerns in regards to viscosity..... obviously you shouldn't go crazy thick! Also the other and biggest concern is that you don't want the fluid to harm the fiber synchros/ harm the glue.....it's been proven that synchromesh doesn't harm the fiber synchronizers.
If I'm wrong then fine but I'd like evidence I'm wrong not just an opinion. What inside of synchromesh will harm our transmission?
Why and how is atf superior?
Btw I installed the fluid today and it is the smoothest it's ever been. Diff pin also looked flawless!
Old 10-15-2019, 08:20 PM   #24
Perhaps reviewing a Saturn training video can help; https://www.youtube.com/watch?v=BBue8XTbcog. A Saturn parts and service manual for your xmission would be invaluable.
Old 10-15-2019, 09:45 PM   #25
dakota1820
What do you think that proves?
My dart for example calls for 0w20 do you think if I run 5w30 it'll blow up? Or get harmed?
Old 10-15-2019, 10:08 PM   #26
I tend to think more info helps in decision making.
Old 10-15-2019, 10:50 PM   #27
dakota1820
Certainly and after the presidential debate I intend on watching the video in its entirety. I just happen to believe that synchromesh atleast amsoil and Valvoline is ok in our transmissions. I would say that Pennzoil is probably to thick in the cold because it is a dino based product. But I don't think these products mentioned will harm our transmissions. There are people way smarter than me that echo this same opinion.
'96 Sl2 Manual Trans Rebuild questions schwghrt S-Series Tech 5 08-09-2009 10:17 PM
94 SL2----Manual Trans questions 2NDSOUT S-Series Tech 2 05-01-2008 07:46 PM
1993 SL2 manual trans questions juspay4speed S-Series Tech 1 12-09-2007 09:52 PM
Manual Trans questions 2NDSOUT S-Series Tech 8 09-11-2007 01:03 PM
Auto trans to manual questions Da_Rockwilder12 S-Series Tech 0 03-11-2005 05:21 PM
