Old 09-05-2019, 01:56 AM   #1
Rj 2000 LS2
Rj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the roughRj 2000 LS2 is a jewel in the rough
2000 L-Series 3.0L Sedan
Default AC Clutch Question
Our 3.0L LS2 AC Clutch is bad. There is a 2.2L Saturn at a salvage yard and the AC Compressor is mine if I want it. Is the AC compressor clutch on the 2.2L different from the AC compressor clutch in our LS2 or are they identical?
Thanks
Rj
Add to Rj 2000 LS2's Reputation
Rate the quality of this post and help Rj 2000 LS2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rj 2000 LS2 is offline   Reply With Quote
Old 09-05-2019, 02:19 AM   #2
pierrot
pierrot's Avatar
Default Re: AC Clutch Question
What is the model year of the donor car?
321,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 09-05-2019, 11:29 AM   #3
02 LW300
02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all02 LW300 is a name known to all
02 LW300's Avatar
2002 L-Series 2.2L Sedan
L300 uses a 6 groove belt and an L200 uses a 5 groove belt. The shoe and the coil will work just not the pulley. The compressor itself is the same.
2002 L200/5 loaded, loving my stick shift car now with KYB struts and adjustable rear control arms.
Add to 02 LW300's Reputation
Old 09-06-2019, 02:24 PM   #4
Rj 2000 LS2
I wish I knew the make and year. I did notice the pulley looked different. What you're saying is the actually clutch coil is identical? Is so, I had better go get that part! Thanks!
Old 09-06-2019, 02:43 PM   #5
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
^^^ That explains why my new compressor had a note about the new pulley Possibly having an extra groove. In my case it did not. The pulley on my old 04 2.2 compressor matched the new pulley correctly.
Thanks for that information!
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 09-06-2019, 03:13 PM   #6
02 LW300
02 LW300's Avatar
I have a 6 groove L300 compressor on my L200 with a 5 groove belt. Happy to help.
Old 09-06-2019, 07:23 PM   #7
Rj 2000 LS2
I got a close look at the 2.2L compressor clutch and it is a ONE Wire connection, not 2 wires like the L200. Our Saturn 3.0L has two wires connecting to the compressor clutch, therefore, I would contend that the 2.0L and 3.0L compressor clutches are not identical.
Old 09-07-2019, 02:02 AM   #8
pierrot
pierrot's Avatar
I believe that 02 LW300 is correct. If you look at the compressors and clutch parts at RockAuto.com then you find that all of the related components are the same except for the pulley. The power connector at each compressor clutch is a two wire type.
Old 09-07-2019, 08:47 PM   #9
02 LW300
02 LW300's Avatar
I was only commenting on factory installed compressors. The aftermarket replacements with the transfer pipe are anyones guess.
Clutch question Rochester S-Series General 3 04-06-2015 09:59 AM
Clutch Kit Question whitesox S-Series General 15 03-28-2015 07:56 PM
Clutch kit question whitesox L-Series General 2 03-27-2015 07:43 PM
act clutch question blue98sl2 S-Series Mods 4 07-12-2008 02:47 PM
Emission Question and Clutch Question Mark92SC2 Miscellaneous Tech 5 09-06-2002 02:36 PM
