Old 10-02-2014, 02:32 PM   #1
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
2002 L-Series 3.0L Sedan
Default 2002 Saturn L300 Dust Shield?
Does anyone know where I can find and order both front brake dust shields at? Looked at eBay but find that confusing since I don't have part number to lookup. I have to go home and check my Service Manuals/Part listing to find that if they even list those.
Add to Russet's Reputation
Old 10-02-2014, 04:58 PM   #2
flyingj
flyingj will become famous soon enoughflyingj will become famous soon enough
flyingj's Avatar
Default Re: 2002 Saturn L300 Dust Shield?
Is it item #6 here? http://parts.nalleygmc.com/showAssem...rimLevel=14954
If so, part number is 21019231.
2001 L-200 2.2l
DOB: 05/08/01 Owned: 07/01/07 to 10/30/18
2006 Vue 3.5L AWD Mileage: 145,000
DOB: 08/24/05 Date Acquired: 12/15/06
2019 GMC Acadia (aka Saturn Outlook)
Add to flyingj's Reputation
Rate the quality of this post and help flyingj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyingj is offline   Reply With Quote
Old 10-02-2014, 06:42 PM   #3
Russet
Do I need to remove anything else I will take the rotor off but I notice the bolts for the dust shield is rusted? Does it requires to remove the hub as well?
Old 10-03-2014, 11:08 AM   #4
flyingj
flyingj's Avatar
From the look of the diagram, it is just the one bolt that holds it on... unfortunately, I had the front rotors of my L200 last weekend, but wasn't paying attention to the dust shield (other than trying not to bang it up while beating the old rotors off).
2001 L-200 2.2l
Old 10-03-2014, 11:31 AM   #5
hacadacalopolis
hacadacalopolis will become famous soon enough
hacadacalopolis's Avatar
2003 L-Series 2.2L Sedan
1996 SC1
There are 3 bolts. They are either Star Or hex. Im pretty sure they are star.
You can turn the hub and use the hole provided to give you access for wrenching.
Add to hacadacalopolis's Reputation
Rate the quality of this post and help hacadacalopolis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hacadacalopolis is offline   Reply With Quote
Old 10-03-2014, 03:33 PM   #6
flyingj
flyingj's Avatar
Ah! So that's what those extra holes in the rotor are for! And here I thought they were just speed holes
2001 L-200 2.2l
Old 10-04-2014, 12:18 PM   #7
Russet
I saw that as well I'll have wait for Summer weather or if summer comes back before winter...it's becoming Winter too soon here... But then I check the part again to reorder it.
Old 06-02-2015, 06:42 PM   #8
Russet
Ok bump to update I checked the site listed and it shows no inventory does anyone else know of another place to look for this???
Old 08-31-2019, 04:57 PM   #9
Chaz9496
Chaz9496 is a jewel in the roughChaz9496 is a jewel in the roughChaz9496 is a jewel in the rough
2001 L-Series 2.2L Sedan
Did you ever find these ? I need them too. I've found only 2 dealers online that still stock them, $16 to $17 each. Other sites show they're discontinued. I would say so. Time to "Bump" again.
Add to Chaz9496's Reputation
Rate the quality of this post and help Chaz9496 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-09-2019, 04:39 PM   #10
Sir Wagonsky
Sir Wagonsky is a jewel in the roughSir Wagonsky is a jewel in the roughSir Wagonsky is a jewel in the roughSir Wagonsky is a jewel in the rough
Sir Wagonsky's Avatar
2008 SKY
2002 L-Series 3.0L Wagon
I'm driving without them right now . They were just too flimsy, full of holes, and deteriorated. I ripped them off easily by hand when I replaced the rotors with my latest sub-frame job.
I saw a few online, 16-$17 each as well.
I also ran into a thread somewhere where the installer makes a cut to get them over the hub. Another set I saw comes precut, but has a those little tin tabs to re-secure the ring.
None of this install looks too difficult once you take the rotor, caliper, and hanger off.
Add to Sir Wagonsky's Reputation
Rate the quality of this post and help Sir Wagonsky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sir Wagonsky is offline   Reply With Quote
Old 09-15-2019, 07:58 PM   #11
pierrot
pierrot's Avatar
^^I believe what you're saying, but I just looked at twenty two online GM OEM parts websites and none showed availability for the part you're that the OP was seeking: p/n 21019231. What dealers were found which said that these dust/splash shields were still available as new replacement parts?
320,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 09-16-2019, 01:50 PM   #12
Sir Wagonsky
2008 SKY
No, sorry if I mislead. I was referring to the dust shield styles in general. I didn't say they weren't GM dealers. They were aftermarket and they were Dorman's. Not specifically your model number, no.
ebay has these : you'll need to cross reference.
https://i.imgur.com/xceakUw.jpg
Those were the two experiences I had, that influenced my post. OP's going to have to substitute. Guess I should have said that. That's why I don't have any on my car with the new subframe, brakes, rotors and (with the alignment ) .. tie rod ends.
My 2002 LW300 3.0 My rotors, exhaust, and customs rims, are from SAAB 9-5 searches. My old ones were beyond recognition. But these will fit 02 SAAB 9-5 SE sedan 4 door 3.0 and assorted -02 Aeros' and ARC sedans and wagons with the 2.3 Turbo. He's got 10. It's the best bet for my car.
Link in a second
Again, sorry to misdirect here. There's got to be pans that will fit or be modified out there once you know rotor size (11.5 for me ) and the hub bolt layout.
Old 09-16-2019, 02:06 PM   #13
Sir Wagonsky
2008 SKY
My links include all my account stats so here's a screenshot of the details of the SAAB I'd like to try. But the mount bolts to the hub don't look right.
Does anyone have a stock image of the original?
https://i.imgur.com/McIBE7C.jpg
Old 09-16-2019, 07:51 PM   #14
Sir Wagonsky
2008 SKY
Try this . Is it the same guy?
https://parts.hendrickchevrolet.com/.../21019231.html
Old 09-16-2019, 10:11 PM   #15
pierrot
pierrot's Avatar
^Good work - congrats on finding a dealership that appears to have the shields available!
Now someone would have to contact them to find out if the items are actually there. I've had this sort of scenario occur where the online dealership source shows an NLA part as on hand, but then someone goes to try and pull the part from the inventory and discovers that the inventory information is incorrect - the item is doesn't exist there. Hopefully that won't be the case with the dealership you found.
Old 09-17-2019, 06:51 AM   #16
Sir Wagonsky
2008 SKY
Thanks . You were right though. I saw a lot were out of stock. Then I found the two-piece Dormans in my Amazon history. But In the reviews the guys were putting them on Silverados and Tahoes.
Gerry Lane Chevrolet / Baton Rouge as well (in addition to Hendrick Chevrolet in NC. )
Both places appear to ship be shipping from their appointed service dept. Promising, but could still ordering out from the same warehouse first.
https://parts.gerrylanechevrolet.com.../21019231.html
Backing Plate (a.k.a. Dust Shield) Needed? RFlaggNY S-Series Tech 1 04-18-2011 01:42 PM
Alternator dust shield missing TomM96 S-Series Tech 3 10-13-2008 06:51 PM
05 L300 - Need bug/rock hood shield Partymmudasti L-Series General 3 12-28-2006 02:53 AM
2002 L300 -- Definately not Saturn's best! drominore L-Series Tech 12 11-07-2006 02:21 AM
Excess Brake Dust - 2003 L300 Ryan L300 L-Series General 23 09-02-2003 11:28 AM
