Old 04-19-2010, 02:29 PM   #1
mrhtwls
mrhtwls is on a distinguished road
Default Vue Struts advice...
The thing I was told about my VUE when it was last in the shop is that it does need front struts. I may take this opportunity to swap the struts and shocks for factory Redline units. Has anyone done this? What aftermarket shock and struts actually fit for the car and handle as good or better than the Redline stuff?
Cheers! ~MrHtwls
Add to mrhtwls's Reputation
Rate the quality of this post and help mrhtwls reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrhtwls is offline   Reply With Quote
Old 04-19-2010, 03:36 PM   #2
D C
D C is on a distinguished road
D C's Avatar
Default Re: Vue Struts advice...
Personally, I would look into OEM Equinox Sport struts. Springs, mounts, and all.
Add to D C's Reputation
Rate the quality of this post and help D C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
D C is offline   Reply With Quote
Old 04-20-2010, 10:02 AM   #3
DavidBo
DavidBo will become famous soon enough
2002 VUE 2.2L
I believe KYB now makes struts for the Vue, IMHO they do make a good part. Your only other aftermarket option that I know of is Monroe, which is more or less a factory replacement.
Add to DavidBo's Reputation
Rate the quality of this post and help DavidBo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DavidBo is offline   Reply With Quote
Old 04-20-2010, 10:31 AM   #4
PortugalFocus
PortugalFocus's Avatar
Has anyone tried the swap? Are they a direct bolt in?
Add to PortugalFocus's Reputation
Rate the quality of this post and help PortugalFocus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 04-20-2010, 11:49 AM   #5
col_dude190
col_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura aboutcol_dude190 has a spectacular aura about
2006 VUE Red Line
2004 ION-3 Quad Coupe
I wondered this as well a few months ago. Based on the pictures I have seen, the spacing of the holes on the Equinox mounts looks pretty similar to the spacing on the Vues mounts, which would mean that the Equinox mounts should be a direct swap to the Vue, but I don't think that anyone on here has actually done the swap.
The strut mounts on the Equinox are held to the body of the vehicle by a set of 3 bolts, unlike the Vue which uses a bolt and a pair of nuts attached to stationary posts on the mount to hold the strut to the vehicle. That seems to be the main difference between the two. Also, even though the spacing looks the same, the bolts may be slightly closer together or further apart, which would make the swap slightly more complicated and would mean that a Vue mount would have to be used.
Add to col_dude190's Reputation
Rate the quality of this post and help col_dude190 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
col_dude190 is offline   Reply With Quote
Struts and Shock Replacement for 2005 RL, any advice? docderek05 Vue Red Line 5 07-25-2008 12:24 PM
aftermarket struts by sprint (xs struts) s-series SL2sleeper S-Series Mods 3 08-19-2006 09:24 AM
About struts... JDub99SL2 S-Series General 18 08-20-2004 11:59 PM
Advice needed on the best aftermarket struts (maybe springs) for a 94 SL2 Fricken eh! S-Series Tech 10 08-20-2004 11:07 PM
Advice, please on sway bar & strut brace advice for 1998 SL2 DOHC. TimothyD S-Series Mods 12 06-21-2002 12:34 PM
