Old 10-15-2019, 02:14 PM   #6241
trottida
trottida's Avatar
Default Re: What did you do to your S-Series today...
Originally Posted by Waiex191 View Post
On the Buick, yes. But if I change the S Series high beams to LEDs what happens to the DRLs? Or did you just do low beams?
The lights look good.
As I understand it the DRL's will not work with the LED bulb. Most sellers indicate so in their advertisement. The LED wont light or will flicker as there is not enough power when in DRL mode. You're good to go with the low beam though.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 10-15-2019, 04:09 PM   #6242
Say, Pitcher, have you tried the new LEDs on a dark country road yet?
In the past 3 years, I used very similar LEDs on my SW2 and LW200 cars.
I could see the light was brighter white, but they did not illuminate better in actual driving conditions and I went back to the Ultra's again.
Old 10-15-2019, 05:23 PM   #6243
Pitcher
Pitcher's Avatar
Not positive on those, but see above.
Owned 4 other S-Series.
Old 10-15-2019, 05:27 PM   #6244
Pitcher
Pitcher's Avatar
You may have bought a dimmer LED. I got brighter ones.
Yes, last night on a very dark road. Much brighter!
1000 Lumens each with Silverstar Ultra
6000 Lumens each with my LED's.
Old 10-15-2019, 07:37 PM   #6245
Pitcher
Pitcher's Avatar
Red Hot is using a bit more oil than she used to.
Probably cause I went from Full Syn to Havoline DS as it's the same timeframe.
Adding Rotella T5 10w-30 a few times to thicken it up a bit.
May switch to T5 fully or go back to Full Syn. Not sure yet.
T5 has more Zinc, Phosphorous & Calcium in it. See how she drinks that.....
Old 10-15-2019, 09:51 PM   #6246
Pitcher, y'all must have entered a typo about lumens.
A standard 60w incandescent bulb is 800 lumens, a 75w one is 1,100, so you might be confused IF you believe a SilverStar Ultra bulb has less light than a 75w bulb. I have seen the Ultra's lumens placed at 1,700 and even at 5,600 (I doubt the 5,600 lumen figure though).
LEDs by nature do not typically go the same distance per lumen that halogens can.
This was my experience with 2 expensive LED sets, bright, yes, but they petered out and could not illuminate the distance I needed so went back to the Ultras.
Old 10-15-2019, 11:07 PM   #6247
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
1996 SC2
1999 SC2
The light he bought does say “6000 lumen/bulb;300% bright than stock Halogen headlights”
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I bought some 9005 for my Chevy Volt 8,000 Lumens they are much better than stock.
Mark_b is offline   Reply With Quote
Old 10-16-2019, 05:03 AM   #6248
Pitcher
Pitcher's Avatar
"The 9006ST (ST = Silverstar) is a low-beam bulb with a 90 degree base. It has a light output of 1,000 lumens, produces 55 watts of heat per hour and has an estimated lifespan of 200 hours." Here & other places: https://itstillruns.com/halogen-vs-xenon-5402741.html
I see numbers all over the place around that amount for the Ultras, so who knows for sure.
Silverstar Watts: 55
LED Watts: 100
Light is being concentrated and reflected back, then directed & projected out, so it's not apples to apples with house light bulbs.
Old 10-16-2019, 08:11 AM   #6249
Copied from the Amazon link, "BRIGHTEST & NO WARNING TICKET: ZES Chips,50 watts/bulb", 100w per set.
Not going to belabor the point, but lumens are lumens and are a measurement of light output, your saturn does not have projector lenses unless you have modified them from factory lenses. Your LEDs are not housed in a projector.
Only difference perhaps between the LED's I had and yours, is that yours seem to have an adjustable ring to change the CW/CCW orientation which may give you a way to obtain a greater light distance (penetration) than the fixed ones I used.
As far as 200 hours of use, I had the silverstar ultras as a set of 4 bulbs, and used them twice daily (1 hour commute each way) for over 70K miles in 5 years of use and never had a ultra bulb-failure.
Old 10-16-2019, 08:42 AM   #6250
Pitcher
Pitcher's Avatar
Checkered Flag Re: What did you do to your S-Series today...
Typical Oil vs Oil discussion, lol
I used to have ultra failures, not so much anymore. Mfg improvements.
Look at the 3 pictures in my Thread. Which do you think is brighter?
http://www.saturnfans.com/forums/sho...d.php?t=238260
When I can see WAY better with the LED's, + a 2 Year Warranty, + cheaper $$ than ultra,
it's an absolute win.
Old 10-16-2019, 08:45 AM   #6251
Waiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of light
Watts per hour?
Old 10-16-2019, 08:46 AM   #6252
Pitcher
Pitcher's Avatar
Watts per hour?
Yea, lol. Watts.
Old 10-17-2019, 06:12 PM   #6253
jpags729
jpags729 is on a distinguished road
jpags729's Avatar
Unfortunately just blessed myself with a nice scratch along the passenger front door. Anyone have any idea where I can buy touch up paint nowadays? Paint code Silver Metallic Clearcoat 11/WA266C. Thanks!
Current:
1999 Saturn SL2 1.9 "Sophia Loren 2"
2007 Subaru Forester LL Bean Edition
Previous:
2008 Honda Accord EX-L 2.4
2007 Chevy Malibu LS 2.2
2003 Nissan Altima SE 3.5
jpags729 is offline   Reply With Quote
Old 10-17-2019, 06:18 PM   #6254
focusofheart
focusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nicefocusofheart is just really nice
Do a Google search and you will find lots of places to acquire the touch up paint you need.
example:
https://www.paintscratch.com/touch_u...11-WA266C.html
I even found it on Amazon.
Saturn 1998 - SL2 automatic
Old 10-17-2019, 06:24 PM   #6255
jpags729
jpags729's Avatar
example:
Thanks for the links! I'll try amazon again I couldn't find it at first.
Current:
Previous:
Old 10-17-2019, 07:38 PM   #6256
jpags729
jpags729's Avatar
example:
Ordered off of Paintscratch! Thanks again focusofheart!
Current:
Previous:
Old 10-17-2019, 09:47 PM   #6257
NWSaturn247
NWSaturn247 will become famous soon enoughNWSaturn247 will become famous soon enough
NWSaturn247's Avatar
Took my car for a walk on Interstate 5 and pegged 40 miles per gallon. Not bad for conditions.
1999 SL2 A4 -92k miles
Currently sipping Delvac 1300 + LM2009
TCW3 dosed fuel
1993 SL2 SOLD @189k
NWSaturn247 is offline   Reply With Quote
Old 10-21-2019, 04:38 PM   #6258
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: What did you do to your S-Series today...
Changed oil and filter 1997 SL1. Out Walmart Synthetic 10w30 and Purolator 20195. In Walmart Synthetic 5w30 and Purolator 20195. Filled up windshield washer checked trans fluid, brake fluid and power steering fluid. All OK!! Ready for winter weather.
1995 SL1 236,300 2005>2018
1997 SL1 79,081 2014>????
CHECK YOUR OIL!!
Old 10-21-2019, 09:07 PM   #6259
454cid
I need to do my oil.... it's over due, and I may need to figure out how to drain my washer fluid. I filled mine up earlier this year with the summer blend that isn't rated for low temperatures.
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
Old 10-21-2019, 10:11 PM   #6260
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Last time I had to drain mine I just removed the one bolt holding it on and dumped it into a bucket. I know 3rd gen has a different bottle shape though and I'm not sure if it's mounted differently. Should be similar though as long as the air pump doesn't get in the way.
97 SL2, auto, 121K miles
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
