Old 08-23-2018, 11:00 AM   #21
DIYguy
DIYguy's Avatar
1997 SC2
Wrench Re: 2nd Gen Interior Center Console Handle 3D Print Model
3D printers are great.
I use mine all the time and have printed many parts for cars.
Mostly I use ABS because of the temperatures, but you do have to paint it because it does not hold up well in sunlight (marginal UV resistance).
DIYguy
Quando Omni Flunkus Moritati
Add to DIYguy's Reputation
Rate the quality of this post and help DIYguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-23-2018, 11:25 AM   #22
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
Default Re: 2nd Gen Interior Center Console Handle 3D Print Model
Originally Posted by cgg17 View Post
Ill try downloading inventor, Ill do the sign up with my school. I am going to try to design door handles for the 1st gens, as mine are worn and floppy...
We should compile a list of things that can be printed, and work away it it.
Next thing on mind was a fog light mount, I've got some fog lights that will be helpful during winter that I want to install.
'97 Saturn SL2 @ 140k
r/Saturn_Cars moderator
Add to jpsuli's Reputation
Rate the quality of this post and help jpsuli reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jpsuli is offline   Reply With Quote
Old 08-23-2018, 01:35 PM   #23
Zeebins
Zeebins's Avatar
After I made my coin holder I though about making a new clip for my sun visor since mine was completely worn out and didn't even hold it in place anymore. I ended up not simply because it was a little to complex of a shape for me to make. Definitely doable though assuming the plastic used to print it could hold up to the sun visor being pulled in and out of it.
97 SL2, auto, 116K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 08-23-2018, 03:19 PM   #24
jpsuli
jpsuli's Avatar
I'll get started on this tonight because I totally forgot about this. Drives me absurd when I place it back in.
Old 08-23-2018, 03:38 PM   #25
This is one of those parts where it might be better checking in a junkyard. Guessing it is a generic part that is direct fit with some other cars.
Came across the idea on another car forum years ago (before 3D printers). Plastic visor clips for a Porsche 944 ran around $25 each, if you could find them and they were decades old. Or you could buy brand new aluminum visor clips from a VW dealer for $4 each
Has anyone mentioned the dome lamps yet? Probably 90% of those little white tabs are broken
Old 08-23-2018, 05:10 PM   #26
jpsuli
jpsuli's Avatar
I thought of it, but are those clear plastic lens removable? The Velcro is holding up just fine!
Old 08-24-2018, 12:42 AM   #27
Zeebins
Zeebins's Avatar
It is. I'm not sure how the switch could be removed though
Powered by Plastic
Old 08-24-2018, 08:17 AM   #28
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
1995 SL2
I wrap clear tape around my visor male end that goes into the female holder, works OK.
1994 Sl2 5spd: 56,576 (Totaled 1/10/2018)
1995 Sl2 5spd Manual Swap: 150,062
1999 Sl2 4spd: 98,8xx
Add to cgg17's Reputation
Rate the quality of this post and help cgg17 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-24-2018, 01:41 PM   #29
Waiex191
Waiex191's Avatar
I got a junkyard visor that was better than the one I had.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 08-24-2018, 03:24 PM   #30
Zeebins
Zeebins's Avatar
I ended up getting a new visor and clip from the junkyard too. The 'new' visor is pretty thin though so it's only a matter of time before that one rips too.
Also, as a little tip for anyone who is looking for a new clip, grab the one from the passenger side. It's the same part and is usually a lot less worn than the drivers side one.
Powered by Plastic
Old 09-14-2018, 09:19 PM   #31
jpsuli
jpsuli's Avatar
I can start making this handle again! If anyone would like to order one I think it'll be like $5 then shipping or free local pickup in MSP. I will be primarily making black, but if you need a specific colour let me know.
Message me via SaturnFans if needed.
Old 09-15-2018, 11:23 AM   #32
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
When mine broke, I drilled the centers about an 1/8"-1/4" deep and put stainless steel pins in them ^ .^
Any chance for 3d printed badges without the "red" sections or red and chrome two different pieces?
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 10-21-2019, 06:34 PM   #33
jpsuli
jpsuli's Avatar
Hey guys,
Just an update. In case the original link dies here is another on Thingiverse: LINK.
Future plans with 3D printer (Will make new thread for each):
-Custom Gauge cluster
Looking to implement the following:
  • DTE
  • MPG
  • Temperature (inside and out)
  • Cruise notification
  • Redline Light
  • OLED screen
- Custom Auto-Climate control
- Sun Visor clip
- Double Din radio integrated on the dashboard (almost done)
Old 10-21-2019, 10:31 PM   #34
98_Gold_Uranus
98_Gold_Uranus's Avatar
You should model out the entire console lid, the bottom plastic portion, so the whole console lid could be rebuilt. Even if it had to be sliced into 3 or 4 parts, printed, and then glued together, it would be stronger then my patched together one that I have in my 98 right now lol.
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-21-2019, 11:21 PM   #35
jpsuli
jpsuli's Avatar
Are you referring to the plastic that is below the handle? I never bother with those even if they break as you have 4 screws keeping it in place.
Old 10-22-2019, 10:13 PM   #36
98_Gold_Uranus
Negative, the entire panel along the bottom of the lid. Doesn't look like there's any screws on mine. I'm almost certain that mine is missing parts lol, but it looks like the top pad and cushion is suppose to have a ring that "clips" into the panel and holds the cover material on. If your's is solid, don't try and pry it apart just for a modeling, I would hate for yours to fall apart too lol
Old 10-23-2019, 04:35 PM   #37
jpsuli
jpsuli's Avatar
Which plastic panel? I think we are talking about the same one. 1, 2, or 3?
Old 10-23-2019, 08:37 PM   #38
98_Gold_Uranus
#1 in your picture there
Old 10-24-2019, 04:20 AM   #39
jpsuli
jpsuli's Avatar
Yeah, that requires 4 screws to keep everything together. The clips do assist in keeping it sound though as you mentioned before, taking these off is almost certain destruction of the piece 'hangers'.
Old 10-24-2019, 09:18 PM   #40
98_Gold_Uranus
Ah okay. I've never actually seen a good solid one, and mine has no screws in it anywhere, so yeah... lol
Center console Jonasan308 S-Series General 8 11-04-2016 10:57 AM
2005 Center Console swap for 2006 model? ScurriVision Vue Red Line 12 04-18-2010 07:52 PM
Interior center console idea CKyAlliance07 S-Series General 20 01-17-2007 09:54 PM
Center Console James Gerber Vue General 6 08-22-2006 01:08 PM
FS: center console and rear console and sunroof deflector 97sc2 Classifieds 12 05-20-2004 03:10 AM
