Old 10-14-2019, 01:08 PM   #21
Waiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of lightWaiex191 is a glorious beacon of light
Default Re: 99 Saturn SL2 engine hesitation, now wonít start
Does the harness look ok? On my 98 it was all corroded.
Old 10-14-2019, 01:12 PM   #22
Check this out:
http://www.saturnfans.com/forums/sho...&postcount=128
Old 10-14-2019, 01:22 PM   #23
ForceEdge
ForceEdge is on a distinguished road
Originally Posted by ForceEdge View Post
Popped it out and car still struggles hard. Car stalls a couple seconds after sitting in park. Have to give gas for it to stat started.
After pulling out service engine light came on
Originally Posted by Waiex191 View Post
Okay weirdest thing just started the car again, ran it, drove it a few 100 feet. Car is running perfectly fine now...
I donít know what the heck is going on but car is purring fine and no hesitation.
ForceEdge is offline   Reply With Quote
Old 10-14-2019, 01:27 PM   #24
ForceEdge
Okay I noticed a lot of white smoke coming out of exhaust when I just pulled off to try and test it again. Cars running fine.
Old 10-14-2019, 04:53 PM   #25
The white smoke, if it isn't a blown head gasket, would normally be first startup and humidity creating steam until the engine warms up. The steam is from overnight condensation settling in the exhaust system. After starting up, exhaust heat begins to heat up condensation and steam comes out the exhaust pipe. We see this during winter driving, less so in summer weather but under humid conditions exhaust steam will come out until the engine's fully warmed up and the exhaust system is too hot to touch. A blown head gasket will make coolant chocolate and motor oil milky with droplets on the dipstick.
How many miles on this engine? Plugs replaced recently? The video seems to show misfiring which can be from a list of things; worn plugs, corroded ignition coils intermittently sparking, plug wires worn to where arcing occurs (seen better at night), lost compression, fuel filter blocking fuel flow, worn out fuel pump, etc.
The check engine light may be from the disconnected intake air temperature sensor. Did you connect the coolant sensor connector to the intake air temperature sensor as suggested, leaving the sensor dangling for the startup test?
Throttle Hesitation After Cold Start MetalMatty S-Series Tech 9 01-03-2015 11:32 PM
1995 Sl1, hesitation, gas to start, forward gear slam geehawk S-Series Tech 7 08-13-2009 01:05 AM
Warm engine hesitation after start up... groover S-Series Tech 0 07-09-2008 11:16 AM
Engine hesitation from a cold start GojuGuy S-Series Tech 6 05-07-2007 03:48 PM
ECTS, rough start, hesitation probs tzec S-Series General 11 09-19-2005 09:24 PM
