Old 03-04-2018, 01:38 PM   #1
Srjs28
Srjs28 is on a distinguished road
Default Random electrical connections 2005 vue
I replaced the motor in my 05 vue. I used the same wiring harness over again and I have to random connections left that I donít know where they go. One is shown in pic attached and it is on a 6Ē lead that hangs on lower portion of motor between the alternator and starter but closer to thr alternator. The othe is off the negative battery cycle. It has 3 leads. One goes to the battery, one to the frame and the other I donít know itís pretty long and can reach down to the lower portion of motor. You guys have any clue?
File Type: jpeg 23BED2B9-9C2D-4D33-8AC4-3A121134BB56.jpeg (101.9 KB, 20 views)
Add to Srjs28's Reputation
Rate the quality of this post and help Srjs28 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Srjs28 is offline   Reply With Quote
Old 03-04-2018, 02:39 PM   #2
waiter21
waiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of lightwaiter21 is a glorious beacon of light
2003 VUE 2.2L
Default Re: Random electrical connections 2005 vue
What engine?
Add to waiter21's Reputation
waiter21 is online now   Reply With Quote
Old 03-04-2018, 05:02 PM   #3
Srjs28
Iím sorry I left that out. Itís A 2.2L ecotec
Old 03-05-2018, 11:12 AM   #4
Srjs28
And can I hook that ground up to the starter mounting bolt that mount to the engine
Old 03-05-2018, 05:04 PM   #5
waiter21
2003 VUE 2.2L
As for the grounds - Look at this link, there are a couple photos that may help..
http://www.saturnfans.com/forums/sho...d.php?t=216101
I'm not sure about the connector in the photo.. I'll climb under mine and take a peek when I get home tonight.... Does it go to the radiator fan??
Does the engine start and run???
Old 03-05-2018, 06:14 PM   #6
Srjs28
Iím not getting spark to my coil. Engine turns over but no spark from plugs. And no it doesnít go to the fan.
Old 03-05-2018, 06:16 PM   #7
Srjs28
I put the ground on the back of the starter, between the engine and trans
Old 03-05-2018, 06:40 PM   #8
Srjs28
Ok. I did the thing with the jumper cable to the ground and then to the plug while plugged into the coil. I found spark. And Iím getting fuel. Still wonít start
Old 03-06-2018, 04:51 PM   #9
Gunz.jones
Gunz.jones is on a distinguished road
That's a sensor plug. Do you have both o2 sensors hooked up? Also, all the intake sensors?
Add to Gunz.jones's Reputation
Rate the quality of this post and help Gunz.jones reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gunz.jones is offline   Reply With Quote
Old 03-06-2018, 06:39 PM   #10
Srjs28
Yes. I have them all plugged in. I found where it went. It was the sensor on the coolant line going to A/C compressor.
2005 Saturn ion random misfire Duhminic Ion General 1 05-23-2017 10:16 PM
2001 SL1 Random starting issues, with electrical loss oceanboy5 S-Series Tech 2 07-12-2016 07:36 PM
What are these connections? Fokkersauras S-Series Tech 9 04-29-2012 11:11 PM
random electrical problems Ajijico S-Series Tech 4 10-19-2011 08:12 AM
Random Electrical Problem Ruzlok S-Series Tech 9 09-25-2009 11:52 PM
