Old 08-10-2020, 04:04 AM   #1
GL4202
GL4202 is on a distinguished road
2002 SL
Default Joining 2 pipes, exhaust
I need to join 2 different sized diameter pipes for a new exhaust. How could I join those 2 pipes with a damn-near airtight seal? I dont want to breathe in fumes obviously but a tiny bit isnt bad as long as the opening doesnt get bigger. Iíll try to check back tomorow with the exact sizes, but i think theyre around 2in-3in. Thank you for your help
GL4202 is offline   Reply With Quote
Old 08-12-2020, 04:13 PM   #2
Default Re: Joining 2 pipes, exhaust
Depends a bit on where you are joining them, but stainless band clamps are a pretty good option
https://www.amazon.com/2-5-Joint-Exh...omotive&sr=1-5
Exhaust adapters and U bolt exhaust clamps are also an option but don't know how long they will last, if rust is a concern
Old 08-12-2020, 09:59 PM   #3
98_Gold_Uranus
98_Gold_Uranus's Avatar
Welding works pretty good for this application
Her name is Uranus :)
Old 08-12-2020, 11:42 PM   #4
They make reducer pipes, though slightly odd ones like 3" down/up to 2" may be hard to find pre-made.
Old 08-13-2020, 10:47 PM   #5
GL4202
2002 SL
I would but id have to rent a welder and find the right settings with no scrap to test on. Just asking for me to mess it up lmao. Ill probly find a in-pipe and clamp. Tired of this CO2
Old 08-13-2020, 10:56 PM   #6
GL4202
2002 SL
Could I find this at an Ace or Menards?
Old 08-13-2020, 11:16 PM   #7
GL4202
2002 SL
Im cutting the midpipe after the cat and attaching it to the elbow after the exhaust manifold. Rust isnt a worry here, could I get the u-bolt clamps at an Ace or Menards?
Old 08-14-2020, 04:50 AM   #8
"Could" you find it there? Maybe...no idea what a general hardware store would have for exhaust size pipe.
I believe this is close, though not exactly, what you need: https://www.amazon.com/Nickson-Indus.../dp/B0049EIBHW
Nickson is the brand O'Reilly's use's, should be able to order that part number from them if they don't happen to have it in stock.
Old 08-14-2020, 06:31 AM   #9
waiter21
2003 VUE 2.2L
Heres a short list of adapters available on Amazon:
https://www.amazon.com/slp/exhaust-a...ovwaa5cy9cj79r
I used DuckDuckGo with the search terms:
2 inch to 2 1/2 inch exhaust pipe adapter
You could plug in your pipe sizes and it should come back with all kinds of sources for adapters. You could either weld these or use a pipe clamp
Old 08-14-2020, 11:20 AM   #10
I've never seen the u-bolt style exhaust clamps at the local Ace/Menards hardware stores.
But every auto parts store (autozone, advance, oreillys, etc) will carry them in wide range of sizes
https://www.autozone.com/emission-co...eVehicle=false
side note, had to open that in a private window, otherwise the stupid website tells me that these universal parts don't fit my Saturn, hurr-durr
Old 08-14-2020, 03:06 PM   #11
Visiting local auto stores stocking exhaust pipe adapters first may turn up what's needed, provided you measured inside and outside diameters of each pipe. If local auto stores don't have what you want, ask if they can order your size. Next step is visiting online to places like summitracing, https://www.summitracing.com/search/...g?fr=part-type to see every possible adapter made for custom work local stores may not carry.
Old 08-26-2020, 11:03 AM   #12
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Try Rock Auto
https://www.rockauto.com/en/tools/exhaust+&+emission
Just watch the shipping costs....
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
exhaust, fumes, joining, piping
Dual Exhaust Pipes? Madness10 S-Series Mods 6 04-06-2014 12:14 PM
Exhaust Pipes Yann S-Series Mods 1 02-05-2008 04:52 PM
How to connect exhaust pipes. Phonespider S-Series Mods 2 01-13-2007 01:29 PM
Installing Exhaust pipes fiestypenguins S-Series Tech 0 09-06-2005 08:20 PM
Vue Redline Exhaust Pipes? andywho2002 Vue Tech 0 03-19-2005 09:31 PM
