Old 09-10-2008, 07:27 PM   #1
annedeslongcham
annedeslongcham is on a distinguished road
annedeslongcham's Avatar
1998 SW2
2001 SL2
Default horn on 98 sw2
My horn on my 98 sw2 doesn't work. I checked the fuse and it wasn't that. Anyone have any idea on what I should check now ?
Add to annedeslongcham's Reputation
Rate the quality of this post and help annedeslongcham reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
annedeslongcham is offline   Reply With Quote
Old 09-10-2008, 07:55 PM   #2
RL2NV
RL2NV is on a distinguished road
2004 VUE Red Line
Default Re: horn on 98 sw2
the horn itself is a pretty common problem
Add to RL2NV's Reputation
Rate the quality of this post and help RL2NV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RL2NV is offline   Reply With Quote
Old 09-11-2008, 05:18 AM   #3
annedeslongcham
1998 SW2
2001 SL2
So your saying it's most likely the horn it's self that probably needs to be replaced? If so is that a easy job to be done?
Old 09-11-2008, 08:28 AM   #4
2NDSOUT
2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice
2NDSOUT's Avatar
1994 SL2
1999 SL
It's not difficult to replace.
The horn is located at the front of the engine near the hood release. Your issue may be the Horn itself or the Horn relay. Either way, you could probably get one inexpensive from the JY, car-part.com or buying one new (the horn and horn relay themselves are roughly about $40 and $24; respectively if you buy them new from Saturnparts.net)
I believe they are held in with either 8MM or 10MM bolts. Been awhile since I have removed one.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 09-11-2008, 09:28 AM   #5
annedeslongcham
1998 SW2
2001 SL2
Happy Re: horn on 98 sw2
ok can someone tell how to take the cover off the relay box that is next to the motor? Do I use the screw driver or does it just pop off? No I'm not blond I just don't want to break something.
Old 09-11-2008, 09:29 AM   #6
annedeslongcham
1998 SW2
2001 SL2
One more thing will I beable to tell if the relay is gone on the horn just by looking?
Old 09-11-2008, 08:38 PM   #7
2SL's&1SC
2SL's&1SC is on a distinguished road
I just replaced the horn on my 98SW2 and it's not behind the hood release. It's down below and on the right side of the drivers side headlight. The easiest way to get to it is remove 2 10mm bolts and unplug the headlight to get it out of your way. Don't think you'll be able to tell if the relay is bad by looking at it.
Add to 2SL's&1SC's Reputation
Rate the quality of this post and help 2SL's&1SC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2SL's&1SC is offline   Reply With Quote
Old 09-12-2008, 09:15 AM   #8
annedeslongcham
1998 SW2
2001 SL2
Is there away I can tell by the horn when I take it out if it's the horn its self that is bad seeing there's no way off knowing if the relay is bad? If I may ask how much did it cost you for the horn? And were you able to get it at a parts store or did you have to get it from a saturn dealer? Thank you..
Old 09-12-2008, 01:09 PM   #9
madpogue
1996 SW2
There's a central knob on the top of the fuse/relay box; turn that counterclockwise several turns.
To test the horn circuit, unplug the horn; you'll see it has a three-wire connector with one orange and two black wires, in a row. Put a DC voltmeter between the terminal for the orange wire and the "outside" black wire. It should read 12V-ish. Then put the negative probe of the voltmeter to the "central" black wire terminal. That should read zero volts. Keep the voltmeter in place while an assistant presses one of the horn buttons. NOW it should read 12V-ish. If all of the above are true, you can be pretty assured that either the horn itself or its built-in relay are bad. It really doesn't matter if it's the relay or the klaxon itself.
Don't have a voltmeter? Get one. It's cheaper than the horn (cheaper than just about any electrical component it's capable of troubleshooting), and will help you with your next electrical issue (and the next, and the next....).
Add to madpogue's Reputation
Old 09-14-2008, 12:49 PM   #10
2NDSOUT
2NDSOUT's Avatar
1994 SL2
1999 SL
Well the horn may have been moved on the 2nd Gen cars, because on my 1st Gen cars, the horn is right next to the hood release in the engine bay, and I don't have to remove the headlight to get to it's location.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 09-15-2008, 04:09 PM   #11
LotusLord
LotusLord is on a distinguished road
1996 SL1
On second gen s-series, or at least my 96, the horn is below the driver side headlight. The relay and horn are one unit.
Add to LotusLord's Reputation
Rate the quality of this post and help LotusLord reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
LotusLord is offline   Reply With Quote
Old 09-16-2008, 12:43 PM   #12
madpogue
1996 SW2
You might do just as well to drive it up on ramps and go at it from underneath. Or have an 18-point whitetail buck smash your fender and fenderwell to pieces, creating an easy reach, like I did.
horn trouble-no power to horn/not fuse 2xsl2 S-Series Tech 6 03-06-2010 11:32 PM
expiermented to day on 97 sc1 horn replaced with honda horn,whadda ya think! maestro S-Series Tech 1 07-27-2007 12:52 AM
VUE horn location - adding 2nd horn? Robert H. Vue Tech 3 09-11-2006 04:20 PM
Two-Horn Setup Help: '96 SW2, Relay Pins 85, 86, 87, 30 ... Brendo613 S-Series Tech 9 12-10-2005 12:58 PM
Horn Dead, Its Not The Fuse , Cant Find Horn justinkr58 S-Series General 2 07-01-2005 06:39 AM
