#1 |
![]() Join Date: Nov 2022
1995 SW2
Of the two, I found location of one under air filter. Can someone direct me to the location of the other one ? 1995 SW2 wagon
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
Near the bottom of the engine on the other side. Same for all models.
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Look in from the front right wheel well with the wheel well liner off and it is right there.
1999 SL2 MT (311,300 km @ 01/2023) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: |
#4 |
Someone needs a water pump ^^^^ (drip.....drip....)
#5 |
![]() ![]() ![]() ![]() Join Date: Sep 2017
That's not the water pump, that's an optional part of the Automated Self-Lubricating Chassis System.
See, cars are known to rust and having a self-lubricating chassis is key to ensuring that the subframe doesn't break down and rust into something akin to a Vega having spent five days in Northern Michigan. The system allows for engine oil to dribble onto the frame and be spread evenly throughout to coat the metal, negating the effects of salt and general weathering. What you're seeing here is the optional Mechanical Engine Bay Air Freshening Unit. One of the drawbacks of the Automated Self-Lubricating Chassis System is that sometimes that oil can get into parts of the engine bay and heat up, causing a dirty and sometimes burning smell. No one likes a smelly engine bay. This unit drips warm coolant directly onto the engine to release a sweet smell that reminds you of grandma's baking on Sunday or your favorite coffee shop (Not Starbucks, however, since that's not actually coffee). I would suspect that he needs to replace the unit as it's beginning to drip on the ground, something that it should never lead to. I assume the high-grade rubber tubing that supplies the unit with hot cooling liquid has rotted away due to age. I do agree it should be changed, since he will have the wheel off anyway, it makes removing the axles easier when you go to pull the engine out to access the unit. |
#6 |
I stole the photo from another post.
#7 | |
![]() Quote:
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg • 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg • 1994 SL1 new traded • 1992 SL2 new traded for above * 1986 Yamaha ce50 Jog -100 mpg |
#8 |
I do kinda wish my knowledge of techno-babble was a bit better :P
Bookmarks |
Aftermarket trans mounts and torque mounts | terminal89 | S-Series Tech | 5 | 07-30-2016 09:55 PM |
Need help torque specs for mounts | Mark121 | S-Series Tech | 1 | 05-23-2016 03:19 PM |
Where to by TAM (torque axis mount) and other mounts? | ModemJunki | S-Series General | 4 | 12-20-2013 07:07 PM |
Where to by TAM (torque axis mount) and other mounts? | ModemJunki | S-Series General | 1 | 12-20-2013 06:52 PM |
WTB 3rd gen torque strut mounts | cleaner13 | S-Series General | 2 | 05-23-2011 07:30 PM |
