Old 12-29-2014, 02:32 AM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question Replacing steering wheel - how do I make sure coil behind steering wheel is ok?
I am replacing steering wheel and the coil just turned and now I see warning that says you have to put correctly otherwise it can damage system and malfunction airbag.
How do I make sure its in correct position?
vikasevan is offline   Reply With Quote
Old 12-29-2014, 06:00 AM   #2
wi111y
wi111y is on a distinguished road
1995 SL
1995 SW2
Default Re: Replacing steering wheel - how do I make sure coil behind steering wheel is ok?
turn it very slowly and carefully in one direction. At some point, you'll feel an increase in the resistance. That's the wire inside being pulled too far that direction. Turn the opposite direction, again, slowly and carefully, and o**** the number of turns.
Turn it back half that amount, and it'll be centered enough.
FWIW, I'm pretty certain there's a few extra turns worth of wiring inside the clock spring, so it being a single turn off shouldn't be a big deal.
'95 SL 5 Speed 220k - DD
'95 SW2 5 Speed 230k - Gone!
'95 Camaro Z28 - Project
'00 Tahoe Z71 - Truck stuff
wi111y is offline   Reply With Quote
Old 12-29-2014, 01:32 PM   #3
billr
"FWIW, I'm pretty certain there's a few extra turns worth of wiring inside the clock spring, so it being a single turn off shouldn't be a big deal."
I am not certain, but don't recall there being that much extra; I would take care to be sure it is centered correctly.
Tags
air bag, coil, sir coil
Need to make my steering wheel inline with the tires. djhhjd Vue General 5 11-17-2010 08:02 AM
leather steering wheel question/steering wheel comment 2006 ion2 Ion General 4 04-29-2010 07:27 PM
Replacing steering wheel LB_BlueVue Vue Tech 4 05-03-2006 06:47 PM
Replacing steering wheel emblem BlueVette L-Series General 12 01-07-2004 10:04 AM
Saturn is replacing my L300 steering wheel! Fish L-Series General 11 08-05-2002 05:29 PM
