Old 04-07-2018, 10:47 PM   #1
That_dumbboy
That_dumbboy is on a distinguished road
2007 AURA XR
Default 2007 Aura XR headlight assembly replacement?
My 2007 Aura XR needs a new passager headlight. There's a crack and allowing water to get inside and and starting to get cloudy and turning yellow. Where should I look to get a new one and how would I go about replacing it myself?
Add to That_dumbboy's Reputation
Rate the quality of this post and help That_dumbboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
That_dumbboy is offline   Reply With Quote
Old 04-08-2018, 09:47 AM   #2
explorerbigjon
explorerbigjon will become famous soon enough
2008 AURA XE
Default Re: 2007 Aura XR headlight assembly replacement?
I've used eBay to get headlights for my car before, usually able to get really good prices there too. Might be able to find one on Amazon as well.
If you're handy with some basic hand tools with some mechanical inclination then you'll be able to handle up on the replacement of the headlight. Requires taking the bumper off which is the worst part of it but it isn't bad.
There are bolts that hold the bumper to the fender, those are tricky to get to but not terrible.
1/4" drive ratchet, varying set of extensions, 10mm socket, 7mm socket, and Philips screw driver should be all you need tool wise.
2008 Saturn Aura XE 3.5-Sport tuning T10 wheels-Dynomax bullet/Borla ProXS-eBay intake-Pioneer Premier 12 shallow mount/Kicker CXA600.1
Upgrades coming!
Add to explorerbigjon's Reputation
Rate the quality of this post and help explorerbigjon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
explorerbigjon is offline   Reply With Quote
Old 04-08-2018, 10:25 AM   #3
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
And I think you can only get 08,09 headlights so if you look close itís a little different.
Add to onefunkar's Reputation
Old 04-08-2018, 11:32 AM   #4
That_dumbboy
2007 AURA XR
What's different about the headlights from the 07 model to the 08,09?
2007 Saturn Aura XR
48k miles
Second owner after parents
Old 04-08-2018, 05:38 PM   #5
onefunkar
onefunkar's Avatar
2008 Outlook XR
2007 AURA XR
Nothing huge. 07s have a ring (shield?) around bulb. 08 and 09 doesnít.
Old 04-09-2018, 10:38 PM   #6
That_dumbboy
2007 AURA XR
Dose this shield around the bulb make a difference the way the light is Projected on the road? And would it look different if I have 2 different headlights then?
2007 Saturn Aura XR
48k miles
Old 04-10-2018, 06:55 AM   #7
explorerbigjon
2008 AURA XE
The 2007 design has a light reflector (described as a shield) on both high beam and low beam bulbs, where as the 2008-09 has just the light reflector on the low beam. Unless you want to change both headlight assemblies to match, I would suggest trying to find the 2007 design headlight, some vendors still sell them.
I do not believe it would make a huge difference in changing the way the light is put on the road if you got the 2008-09 design headlight.
Upgrades coming!
Old 04-11-2018, 03:27 PM   #8
That_dumbboy
2007 AURA XR
Thanks for the Information. I think I'll try to find the 2007 headlight. I like the way it looks with both of the shields.
2007 Saturn Aura XR
48k miles
2007 Aura Vent valve replacement alfisalive Aura General 0 12-26-2014 10:42 PM
2007 VUE Headlight Switch Replacement / Temporary Bypass? ram17x Vue General 1 11-23-2014 01:44 PM
2007 Aura XR bottom grill replacement audiofx Aura General 5 06-15-2010 04:29 PM
Aura Headlight and Foglight Replacement!!!!!! Riicky Aura General 5 03-15-2010 08:27 PM
Headlight assembly SaturnRider S-Series General 4 09-06-2008 03:07 AM
