Old 07-28-2012, 12:35 PM   #1
lgates3522
lgates3522 is on a distinguished road
Default Very strange blinker issue... Wierd!!
I have an 02 Saturn Vue. For the last month or so my blinkers would turn on (by me) then randomly shut off.
Here's the strange part...
Blinker on to turn right... It randomly goes off...
I push the hazard button on.. Then off..
Blinker turns back on for a short period of time.
What's causing this and is it an easy fix?
2002 Saturn Vue AWD 3.0
Add to lgates3522's Reputation
Rate the quality of this post and help lgates3522 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lgates3522 is offline   Reply With Quote
Old 07-28-2012, 12:58 PM   #2
99WhiteC5Coupe
99WhiteC5Coupe will become famous soon enough99WhiteC5Coupe will become famous soon enough
Default Re: Very strange blinker issue... Wierd!!
The turn signal function is routed through the 4-way emergency blinker switch. Since the problem is intermittent, I suspect you will have to replace the 4-way blinker switch to correct the problem.
Similar problems occur on the C5 Corvette - the switch becomes oxidized and malfunctions. Some people have found that operating the 4-way blinker switch on-and-off several times cleans the switch contacts briefly, and returns the turn signal operation to normal.
Good luck.
Add to 99WhiteC5Coupe's Reputation
Rate the quality of this post and help 99WhiteC5Coupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99WhiteC5Coupe is offline   Reply With Quote
Old 08-01-2012, 08:07 PM   #3
99WhiteC5Coupe
Any update?
93' SL2 Hazard/Blinker Issue... Colgate41 S-Series Tech 3 04-19-2010 06:33 PM
Wierd acceleration issue? Aratech Aura General 19 06-30-2008 07:30 PM
'99 Sl2 wierd electrical / start issue budro49 S-Series Tech 5 02-17-2008 01:07 PM
wierd wheel issue ad198592sl2 S-Series General 2 10-18-2006 09:56 AM
blinker issue defy69 Ion General 13 05-13-2006 04:05 PM
