Old 09-11-2019, 07:25 PM   #1
Cavell
2003 VUE 3.0L
Default Wheel squeak bearing?
Got a rhythmic squeak from wheel. Jacked up front and pass wheel bearing is a bit noisy. Ordered bearing. Today I jacked up rear and seems pass rear is noisy too. Huh? 2 wheel bearings? But, a bearing does not squeak, does it? I spun all 4 wheels and I cannot find squeak
Old 09-13-2019, 06:12 PM   #2
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Wheel squeak bearing?
...I don't know if this pertains to your situation, but , my vue had a similar noise from the rear. I think it was where the half shaft goes into the rdm, the seal , possibly the spring in the seal had worn thru the rubber , and when the halfshaft rotates , it makes that noise. I managed to stop the noise, cheaply , by spraying white lithium grease around where the halfshaft goes into the rdm. The noise stopped for a while, only appearing sometimes after raining or when really cold out, just a thought that might help, DC
Old 09-16-2019, 01:04 PM   #3
tcndeb
tcndeb will become famous soon enough
2004 VUE 2.2L
Might need weight on it to make it squeak, although a wheel bearing squeak would be a very fast squeak. The bearings I have had go bad tend to rumble more than squeak.
'04 Base Model Vue, 2.2, 5 Speed
tcndeb is offline   Reply With Quote
Old 09-16-2019, 05:17 PM   #4
Cavell
2003 VUE 3.0L
Turned out be be backing plate. Lower edge next to ball joint
Bad Front Axle Bearing (Not wheel bearing) ? cjhsa Vue General 19 08-08-2017 08:56 PM
Monroe Quik Struts - Squeak, Squeak, Squeak simpsondb S-Series Tech 119 07-19-2016 08:47 AM
Front wheel squeak. Vulcansat S-Series Tech 2 09-06-2012 11:10 AM
Squeak When Wheel is Turned to Right datlas S-Series General 2 04-16-2012 03:13 PM
wheel squeak briansc1 S-Series Tech 0 07-24-2008 04:05 PM
