Old 11-28-2009, 08:54 PM   #1
Quadragin
Quadragin is on a distinguished road
Default Ignition Key Stuck, Will NOT Turn or Come Out
I have a 98 SL2, with a bunch of miles.
The Key will not come out of the Ignition, It is currently in the off postion.
I can not turn the key to acc, or on.
The steering wheel turns freely, I can how ever turn it to a point were I can feel were the steering wheel lock is at, but will turn beyond that point.
Here is what I have tried;
WD-40
Wiggiling the key while pulling
Wiggiling the key while pulling with clutch in
Wiggiling the key while pulling with clutch in, and turning wheel
Wiggiling the key while pulling with clutch & break in, and turning wheel
Moved gear shift back and forth while jiggleing key.
Pulling on it with pliers
Disconnected battery, and everythnig above
Reconnected Battery and everything above.
Its like the soleniod that holds the key in is stuck.
Thank You
Add to Quadragin's Reputation
Rate the quality of this post and help Quadragin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Quadragin is offline   Reply With Quote
Old 11-28-2009, 09:41 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: Ignition Key Stuck, Will NOT Turn or Come Out
try wiggling the key while pushing it in and turning the wheel slightly then pull the key out. pressing the clutch and/or brake and/or shifting gears won't do anything. you may need to get a new key cut or new ignition cylinder.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 11-28-2009, 09:43 PM   #3
Quadragin
Default Re: Ignition Key Stuck, Will NOT Turn or Come Out
Ya been there done that...
Old 11-28-2009, 10:48 PM   #4
Phyzik sl2
Phyzik sl2 is on a distinguished road
well mine is automatic but i think the manuals have the same thing. there should be a braided cable that runs from the shifter to the steering column. It controls the lock cylinder. Take that cable off the shifter and just let it hang, you should be good.
Add to Phyzik sl2's Reputation
Rate the quality of this post and help Phyzik sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phyzik sl2 is offline   Reply With Quote
Old 11-28-2009, 11:51 PM   #5
Canyon
Canyon has a spectacular aura aboutCanyon has a spectacular aura about
1999 SL1
There is a bell crank in the shift console that determines if the shift lever is in park. This bell crank gets dry and doesn't go to the park position. This happened on one of my daughters car. She would wait and after a while she could get the key out. I opened up the console and sprayed WD40 on the bell crank and she never had the problem again.
Add to Canyon's Reputation
Rate the quality of this post and help Canyon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Canyon is offline   Reply With Quote
Old 11-29-2009, 08:09 PM   #6
Quadragin
OK I got it Out.
I tried waht others stated, the manual trans does not have a lock out.
I ended up pulling the ket out with plyers, hitting ignition with a hammer this dislodged it.
I inserted the key turned to the on position, took a little screwdriver and pressed in on the lock tab
Removed the ignition tumbler cleaned it with carb cleaner and put it back in.
Works good enough until I buy a new tumbler.
Key Stuck in Ignition corbins Ion Tech 29 11-26-2013 05:46 PM
Key stuck in ignition Ziek Aura General 6 10-13-2006 04:22 PM
key stuck in ignition saintfn1 S-Series Tech 8 12-11-2005 09:44 PM
Spare key gets stuck in ignition, main key doesn't 94sc293sl1 S-Series Tech 7 07-12-2004 12:03 AM
Key stuck, very hard to remove key from ignition... Actaeon S-Series Tech 7 12-21-2003 12:08 AM
