Old 03-09-2008, 07:30 PM   #1
C130Flyboy
C130Flyboy is on a distinguished road
Default '98 SL2, Hard to turn key in ignition - will not start
Another problem with my 98 SL2 with 123,000 mi. I went to start the car and the key had a hard time at first turning the ignition. Once it did, all check lights came on and then nothing. No start. Battery is good, Car is in Park. I thought this may be related to the security system, this checked out ok too. I removed the key a few times and turned the steering wheel to unlock it and then the key slid in like it should and the car started. Is this the Key? or could this be the ignition switch?
Add to C130Flyboy's Reputation
Rate the quality of this post and help C130Flyboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
C130Flyboy is offline   Reply With Quote
Old 03-09-2008, 08:44 PM   #2
Default Re: '98 SL2, Hard to turn key in ignition - will not start
Check the threads for '98's having the first lame anti-theft system by way of a starter relay interrupt wired haphazardly and taped into the wire bundle along the steering column. There's a picture of it floating around to identify the common '87' relay. It may be faulty and preventing the starter from powering up.
Old 03-09-2008, 09:35 PM   #3
Actually it was '97. And it doesn't sound like it's the problem, if the key turned and the engine started normally after turning the wheel. A fresh key (DON'T get a copy of your original; have a NEW one cut based on the VIN) might help, but it might just be a case of "Doctor, it hurts when I do this....well, then, don't do that." IOW, when you remove the key, don't turn the wheel to lock the column, or if you do, turn the wheel again to "unload" the column lock from the ignition cylinder when you go to start it again.
Add to madpogue's Reputation
Old 03-09-2008, 10:39 PM   #4
I hate it when I have to be reminded I'm wrong, again!? Thanks M.
Ignition Key Stuck, Will NOT Turn or Come Out Quadragin S-Series Tech 5 11-29-2009 08:09 PM
Key doesn't turn in ignition 98SaturnSL1 S-Series General 5 01-27-2009 04:55 PM
Key hard to turn 01SL1SATURN S-Series Tech 2 08-08-2008 06:44 PM
Key won't turn in ignition moore_y Vue Tech 9 05-20-2006 09:18 PM
Key stuck, very hard to remove key from ignition... Actaeon S-Series Tech 7 12-21-2003 12:08 AM
