Old 05-02-2006, 11:19 AM   #1
moore_y
moore_y is on a distinguished road
Default Key won't turn in ignition
2003 Saturn Vue V-6 AWD. No major problems except now. Key wouldn't turn in ignition yesterday (for the 1st time). Was finally able to get it to turn after turning wheel to the right (hard). Got home, called the dealership, they said that it was either the ignition cylinder or the key could be worn. I got my spare key and noticed that there were 2 pieces missing out of the current key. I tried the spare and it has worked fine ever since. I am taking my car in on Saturday to get the oil changed but my question is, do I need to have them check the ignition? Do I still need to worry about this?
Thanks for your help!
Add to moore_y's Reputation
Rate the quality of this post and help moore_y reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
moore_y is offline   Reply With Quote
Old 05-02-2006, 01:29 PM   #2
mr_mike
mr_mike is on a distinguished road
2006 VUE 2.2L
Default Re: Key won't turn in ignition
It was very likely that the problem turning the key was due to the steering column lock mechanism. Sometimes when you lock the steering wheel, if you the mechanism will bind up, making it difficult to unlock the ignition with the key. Often when this happens, you will be parked on a hill with your wheels agains a curb or some such item. Once you turn the wheel hard to the right (or left), the pressure is released on the locking mechanism, and the key will turn easily. This is a similar situation to what can happen in an automatic if you park on a hill without the parking brake.
As regards to the regualar and spare keys looking different, on some occasions, keys cut from the factory code will have one cut different than the keys that came with the car (and any that were duplicated in a machine from those original keys). I have found that to be the case on many of my GM cars over the past 10 years. It is usually the closest cut to the head of the key, and has never seemed to make much of a difference.
Hope this helps, and in short, it seems to me it was a one time thing based on the parking at the time, and not something broken with the car.
Mike
Add to mr_mike's Reputation
Rate the quality of this post and help mr_mike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr_mike is offline   Reply With Quote
Old 05-02-2006, 01:53 PM   #3
moore_y
Thanks for your Reply Mike. I do appreciate it. In short, the Original Key that I have been using for the past 3 years, will only work if I lock the steering column and turn the steering wheel to a "Hard Right". The Spare Key that also came with the car, works whether I crank the steering wheel or not. The differences that I noticed in the 2 keys, was that 2 "chunks" were missing from the Original Key and had visibly broken off.
I still am unsure whether this is just that the key finally wore down, or if I have a much larger problem with the Ignition cylinder.
Old 05-02-2006, 02:38 PM   #4
Tom92SCm
Tom92SCm has a spectacular aura aboutTom92SCm has a spectacular aura about
Tom92SCm's Avatar
Sounds like you need a new key.
Mine sticks sometimes as well. But like Mike said, it's related to when the steering column lock has been engaged.
I had an '82 Celebrity that I HAD to turn the wheel while turning the key in order to make the electrical connection to get it to start. Pretty weird. That car was a pile of junk though.
--Tom
Not a Saturn.
Add to Tom92SCm's Reputation
Rate the quality of this post and help Tom92SCm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom92SCm is offline   Reply With Quote
Old 05-02-2006, 03:08 PM   #5
IMkenNY
IMkenNY is on a distinguished road
Try lubricating the lock cylinder.
Even though ignition cylinders are not subjected to the outside elements that the door locks get hit, they still require periodic lubrication.
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Old 05-02-2006, 08:35 PM   #6
burlyvue2
burlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura aboutburlyvue2 has a spectacular aura about
2004 VUE 3.5L
2000 L-Series 3.0L Wagon
Bad Key for my 2003 Vue also. Get the Saturn Parts dude to make you a new key and keep another spare in your wallet. They can determine the keys code from the vehicles VIN.
If you lubricate your ignition cylinder use graphite (dry black powder) and not use any kind of oil, especially WD-40. That will gum up your locks quicker than anything.
Add to burlyvue2's Reputation
Rate the quality of this post and help burlyvue2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
burlyvue2 is offline   Reply With Quote
Can't remove Key from Ignition or turn off engine!! stickdog Ion Tech 12 07-18-2010 11:48 AM
Ignition Key Stuck, Will NOT Turn or Come Out Quadragin S-Series Tech 5 11-29-2009 08:09 PM
Key doesn't turn in ignition 98SaturnSL1 S-Series General 5 01-27-2009 04:55 PM
1999 SL - Ignition key will not turn AT ALL!!! HELP! 2002SaturnMan S-Series Tech 6 08-13-2008 09:48 PM
'98 SL2, Hard to turn key in ignition - will not start C130Flyboy S-Series Tech 3 03-09-2008 10:39 PM
