Old 09-30-2012, 10:50 AM   #1
Toolman11k
Toolman11k is on a distinguished road
Arrow - 2002 Saturn SL2 - Security Light & Wrench Light on
2002 Saturn SL2 - Automatic, RKE
I have read countless postings similar to this, but no one has a good solution. Interested in knowledgeable feedback.
I had a ignition cylinder that was bad (key pulled out any position) and the housing was loose on the column. I got an entire column from the junk yard, not 100% sure if it was a 2001 or 2002 column. I only used the Ignition cylinder housing, the switch and the Ignition Key / Core.
Here lies the issue:
Just like everyone else, I had a no start after replacing the housing. I plugged the old housing back in and use the new switch and the car started fine. I plugged in the new switch and it also now works fine. The only issue is the security light is on, and the wrench light is on.
I tried the manual reset procedure (with a trickle charger hooked up) and still the same issue. Car runs fine, starts fine, still has a light on. (10min - 3X)
I have about 3 different scan tools here, and none of them have the ability to read any codes or clear any codes related to this. I have a Launch Diagun, OTC Genysis, OTC Pegysis. The diagun can get into the BCM (according to it's menus), but there are no codes.
Do I need a Tech 2 to reset this, is it possible? Can any GM dealer do this now that Saturn is no longer.
Any thoughts or ideas?
Add to Toolman11k's Reputation
Rate the quality of this post and help Toolman11k reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Toolman11k is offline   Reply With Quote
Old 09-30-2012, 01:18 PM   #2
Default Re: - 2002 Saturn SL2 - Security Light & Wrench Light on
Performed the 30-minute relearn procedure?
Old 10-02-2012, 07:09 AM   #3
Toolman11k
Yes i did. I ended up switching back the original housing and all is fixed now.
Security light and Service wrench on masterm6 S-Series Tech 4 11-22-2011 09:28 AM
help asap...security light wrench light Ruger141 S-Series Tech 7 01-28-2011 02:08 PM
2000 sl2..wrench and security light reset? duke73 S-Series Tech 3 10-09-2009 10:46 PM
wrench & security light hengster S-Series Tech 5 01-26-2009 01:44 AM
Intermittent Security light- 2002 L200 L4 boomerang86 L-Series Tech 0 08-25-2005 06:44 AM
