Old 01-15-2003, 08:44 AM   #1
cincysaturn
cincysaturn is on a distinguished road
Post Brakes dragging (I think)
I'm just now getting around to posting this but when I put new brakepads on my front wheels several months ago, I noticed they looked like they were touching the disks. Even now they still look very close. Is there any way to adjust how far away the pads are from the disk? Also, do saturn typically have responsive brakes because mine are somewhat mushy. Even after bleeding them and seeing there was no air in the system.
Thanks.
Add to cincysaturn's Reputation
Rate the quality of this post and help cincysaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cincysaturn is offline
Old 01-15-2003, 09:00 AM   #2
wolfman
wolfman's Avatar
Default
The pads SHOULD touch (lightly) the rotors. Properly adjusted, (automatically) the gap between the pads and rotors is literally MICROSCOPIC. If your pedal is "mushy" either you got air IN the system when you bled the brakes OR a problem exists in the hydraulic system somewhere (master/lines/calipers/slaves) OR the REAR shoes are backed out TO FAR and need to be adjusted.
Add to wolfman's Reputation
wolfman is offline
Old 01-15-2003, 11:30 AM   #3
eRic 02sc2
eRic 02sc2's Avatar
Default
some rotor drag is normal. make sure you clean and lube the clips, guide pin and lock pin to make sure they release properly, however.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 01-15-2003, 04:06 PM   #4
cincysaturn
Default
Thanks for the help. I might inspect the rear drums if it ever warms up. It's so hard to work on a car when it's in the 20's!
brakes dragging 04Vuesilver Vue Tech 4 05-05-2009 09:51 AM
dragging brake quiksc2 S-Series Tech 22 09-26-2008 11:47 AM
Intermittent Dragging Brakes brian111 L-Series Tech 5 08-21-2007 03:55 PM
Dragging an ION Iceberg18 Ion Mods 62 01-22-2006 02:46 AM
Everybody's dragging their feet bobwill Ion General 6 06-02-2003 09:38 PM
