#1 | ||||
![]() Join Date: May 2008
![]() So i watched rich pins vid on how to remove the center counsel and i got it off and since i found out the BTSI was the reason my key wasant coming out, so i figured i would oil the linkage and all of the moving parts under the counsel ! so i did that and i did some adjusting and it worked better but still not to the point were anyone can just jump in the car and expect it to work.soooo for the 3rd time i took off the steering colum trim and found that the BTSI cable hooks to the bottom of the key cyl ! and was held on by 3 tabs ! and soooo easy to just take it off !so i did and my problem is solved ! i honestly dont see any problem with what i did , and dont think it will cause any issue's but some input would be be nice ! But wow it works soooo much better.Here are a few links and here is a pic of my nice HVAC lights that i RE did ! it sure looks nice
http://i831.photobucket.com/albums/z...202010/009.jpg http://i831.photobucket.com/albums/z...2010/007-1.jpg http://i831.photobucket.com/albums/z...2010/011-1.jpg ... 1997 sl2, auto I love the greaters too...you can't even tell who the *** he is greating. Both of his eyes are looking different directions. You only go to walmart for comic relief.
#2 | ||||
![]() Oil eventually causes trouble by collecting dirt and then it gums up the cable. Usually flushing with a solvent like the CRC electrical Connection cleaner and then dusting with powdered mica lasts much longer.
#3 | |||||
![]() Quote:
also i am thinking about removeing the whole cable including the electrical silinoid that is plugged in.will that set a wrench light ? ... 1997 sl2, auto I love the greaters too...you can't even tell who the *** he is greating. Both of his eyes are looking different directions. You only go to walmart for comic relief.
#4 | ||||
![]() It may set a code, don't know for sure. Removing the installed idiot proofing is fine as long as the driver is smarter than the car.
![]() Powdered mica is just that mica that has been ground to a very fine powder. Mica is a rock. You can get a lifetime supply at most good gun shops. You do not need much. Graphite will clump into lumps over time and gum up the works.
Another how much would you pay thread XD | Defcon | S-Series General | 4 | 07-05-2008 06:46 PM |
Another EGR Thread | LotusLord | S-Series General | 14 | 10-02-2007 10:42 AM |
Constant "ticking" noise; same at idle same at 5.5k RPM last year - THREAD FOLLOW UP | SR20FL | S-Series General | 0 | 08-11-2007 07:28 PM |
Another A/C Thread... | DTDSasquatch | S-Series Tech | 2 | 05-03-2006 11:16 PM |
yet another thread | jjsk8r85 | S-Series Tech | 19 | 02-05-2005 10:15 PM |
