Old 09-13-2007, 10:20 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Wheres the EVAP purge solenoid located on the 92 Sl2?
Where is the EVAP purge solenoid located on the 92 SL2? And what does it look like? Does anyone have a picture of it?
92 SL2, 5 speed
91 Lx 5.0
Add to turbobuick33's Reputation
Rate the quality of this post and help turbobuick33 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
turbobuick33 is offline   Reply With Quote
Old 09-13-2007, 10:24 PM   #2
Default Re: Wheres the EVAP purge solenoid located on the 92 Sl2?
Under the intake manifold above the starter. Track the vacuum line from the throttle body area that goes to under the intake. This will lead to the cannister purge solenoid.
Add to ssicarman's Reputation
Old 09-14-2007, 10:40 AM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 09-14-2007, 10:42 PM   #4
turbobuick33
1992 SL2
Is this solenoid held by a bolt or by clips?
92 SL2, 5 speed
91 Lx 5.0
Old 09-14-2007, 11:05 PM   #5
richpin06
richpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the roughrichpin06 is a jewel in the rough
richpin06's Avatar
Just one bolt.
Add to richpin06's Reputation
Rate the quality of this post and help richpin06 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-14-2007, 11:06 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
By one 10mm bolt.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-14-2007, 11:13 PM   #7
Low Saturn
Low Saturn's Avatar
2000 SC2
Originally Posted by Low Saturn View Post
By one 10mm bolt.
Now that I think of it, it may be a 8mm bolt.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-15-2007, 12:12 AM   #8
Second guessing yourself. 10 mm head bolt.
Old 09-15-2007, 01:15 AM   #9
turbobuick33
1992 SL2
Another question, can the solenoid be removed from the top? Or does it have to be removed from underneath the car?
92 SL2, 5 speed
91 Lx 5.0
Old 09-15-2007, 11:53 AM   #10
BarnOwl
BarnOwl's Avatar
Unless you have more than one elbow on each arm, you'll have to do it from underneath. The bolt's kind of tricky to get at. I did it with a 1/4 in drive socket and a wobble extention. However, some people just leave the old one in and use cable ties and tie the new one to it.
Add to BarnOwl's Reputation
Old 09-15-2007, 08:19 PM   #11
93goldsl2
93goldsl2 is on a distinguished road
1993 SL2
That's what I did- the bolt was stuck. Good idea to disconnect the battery, you'll be relatively near the hot on the starter.
Add to 93goldsl2's Reputation
Rate the quality of this post and help 93goldsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93goldsl2 is offline   Reply With Quote
Old 04-01-2013, 09:26 AM   #12
sistahazel
sistahazel is on a distinguished road
1992 SL1
1992
I think this is a rediculous question, but after I replaced a hose that had a hole in it, my car isnt running correctly. So, does it matter if the hose coming from the Throttle body goes on the top port or bottom port?
92 Sl1 SOHC
Add to sistahazel's Reputation
Rate the quality of this post and help sistahazel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sistahazel is offline   Reply With Quote
EVAP canister purge solenoid location CA-Legal-Vette S-Series Tech 3 10-19-2008 05:41 PM
EVAP purge solenoid hufhouse L-Series Tech 3 01-04-2008 11:49 PM
93 SL2 Purge Solenoid Partymmudasti S-Series Tech 2 11-20-2005 09:16 AM
93 SL2 Purge Solenoid help! Partymmudasti S-Series Tech 13 10-18-2005 10:19 AM
evap canister purge solenoid Hittman S-Series Tech 7 01-29-2004 11:06 AM
