#1 |
I'm trying to track down an oil leak in a '97 SL1. I'd seen mechanics use this fluorescing dye to find out where the leak was coming from and found out that the dye only cost like $5.00 from NAPA. I put the dye into the crankcase and waited for a week of driving the car so that the dye would have a chance to leak out. I went and bought a 60W black light bulb to look for dye and didn't find anything stained. I tried just fluorescing the dye, and found that I couldn't see it fluorescing much, even if I darkened the garage.
A mechanic suggested that I needed a brighter UV source (maybe more focused than what I'm using) and perhaps a pair of fluorescence enhancing googles. I looked these up on the Internet and found that the prices for these things range from about $30-$200. Does anyone have experience with this sort of thing? Can I get away with just buying the $30 kit and actually have a chance of finding the leak? Or even better, can I juryrig something with the 60 W black light I've got so that the dye will actually fluoresce. Thanks. |
#2 |
![]() Join Date: Jan 2005
I can't answer you concerning what you can do to enhance your black light source other than getting a brighter or more focused one. Other than that, I have used these dyes and they have worked pretty well for me. But I also start with a clean engine. Actually if you clean your engine thoroughly, many times that is all you need to do. Fresh oil on a clean engine becomes pretty evident. Also the fresh oil should have the dye in it that you put in and should show up pretty readily with the black light.
1999 SC-2 280,000 miles -mine now also dead, RIP 1995 SL-2 296,000 miles - my wifes totaled, RIP 1993 Chevrolet S-10 Pick-up - mine 2003 Harley Davidson Low Rider - mine |
#3 |
Another trick you might try is to clean the engine and spray it with a spray powder, like foot powder. This should make it pretty easy to see where the oil is coming from.
There is nothing more frightening than ignorance in action. |
Bookmarks |
UW Leak detection.. | off-track | S-Series Tech | 7 | 05-07-2009 08:56 AM |
SL2 oil leak & Rear oil seal kit parts id | jimmmm | S-Series Tech | 1 | 10-25-2007 02:50 PM |
Oil Leak? Not oil pan, not valve cover, not front oil seal. | klcl | S-Series Tech | 14 | 10-05-2007 12:25 PM |
Speed Detection Circuit??? | LIMEQuadC3 | Ion Tech | 3 | 12-08-2006 09:47 PM |
radar / lidar detection question | abkaiser | Miscellaneous Tech | 7 | 12-09-2000 12:30 PM |
