Thread Tools | Display Modes |
![]() Join Date: Aug 2005
1994 SW2
I have noticed a rust problem on my 1994 SW2, that is in the same spot on both sides of the car.
It's rusting under that plastic thingy which is the trim that sits on top of the rocker panel. It's under the door when the doors are shut. My other question is how do I fix this. I was going to just scrape it down with a wire brush and get all the loose flakes off. Then pop rivet a piece of steel on it and try to match it with some paint of the same color. Does anyone else have this problem? What can I do to prevent this from happening after I fix it? What did you do to fix it? |
![]() Join Date: May 2004
1993 SL2
you really can't do anything about it...and it'll only get worse.
The door sill plate is notorious for rust in snow felt areas. |
1994 SW2
"DOOR SILL PLATE"
Aha, I knew it was called something. Well, That just freeking sucks. I'm going to get started on this project today. Hopefully, I can fix it. I had a similar problem on a 1992 Cavalier. I rebuilt the rocker panels on both sides, using 16 - 18 guage steel (I forget). Supplies didn't cost that much. A 4X3 piece of stainless steel cost about $20.00. Alot cheaper than your local hardware store, mostly because I went to a supplier. I bent the steel by borrowing my buddies aluminum siding bender. Then I put a pop rivet in just about every inch around the perimeter of the new rocker panel. Afterwards I went with some bondo, and put it where the rivets were placed, sanded it smooth, primed it-(one-coat), Painted it-(3-coats), Clear coat-(3-coats). I thought it would very difficult to match and blend the paint, so I ended up painting them black. I'm not a expert when it comes to body work. Plus I never attempted anything like this before. But I bought that car with 71000 on it off the state of Ohio for $1100 dollars. I put 35000 miles on it and only put about $400 into it. Most of it went into making the car look nice. But, I ended up selling it for $1700. I knew I wouldn't get what wanted for it if I didn't fix the rocker panels. So for about $75 and 8 hours of labor which stretched in 2 weekends, I did it. I gave myself a that-a-boy. I'm still in search of anybody who has encountered this problem and how did they solve it for their Saturn on the "Door Sill Plate". |
![]() Join Date: Jul 2002
All you can do is slow rust down.sounds like you are going about it the right way.GOOD LUCK!
#5 |
![]() Join Date: Dec 2003
1994 SL2
Find a body shop that'll do it. My Dad had his passenger side replaced, and I know I need to have both of my rocker panels replaced. Unfortunatly it is kind of expensive, it's like $300 per side where we take them. The work is premium though, they do a beautiful job and it usually looks factory fresh... IMO have it done right.
![]() Join Date: Jul 2005
I had those replaced for about 150$ per side, but the rust wasn't TOO bad so I got off easy.
In short, yes they all rust there.
Madness takes it's toll: Please have exact change. SES light + unplugged sensor = testicle ownage. |
#7 |
Is the door sill plate the same thing as the inner rocker panel? The inner rocker is available from saturn for under $50.00.
Former Saturn Owner Struck by "Unresponsive" and "Inattentive" Treatment from Toyota | Charlie | General Saturn Discussion | 20 | 02-25-2011 05:11 PM |
"chrome" plastic door molding? | 20VUE06 | Vue General | 1 | 05-01-2009 05:09 PM |
"New" SL1 2002 "Potential" owner with Questions | MBman | S-Series General | 19 | 03-01-2006 01:43 AM |
Im starting to think "Saturn" will be switched to "OPEL" by 2010! | johnsocal | General Saturn Discussion | 12 | 10-28-2003 03:05 AM |
"L" series owners: Seeking the "LOW" life? | Abe95SC2 | Mods and Performance | 8 | 02-04-2002 11:19 AM |
