Old 09-03-2016, 08:39 PM   #1
xdarkxfirex
xdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura aboutxdarkxfirex has a spectacular aura about
Default Alignment Problems. Need help in the right direction
When I bought the car cheap, it first I didnt notice the camber was off. It looked like the previous owner hit a pothole deep enough to hit the top of the fender. Have tried alignment but the shop I went to didnt know, or care why it was off. The camber was -2.4 on one end, and -0.4 on the other.
The caster was off on both wheel. What do you think is the best way to fit it?
xdarkxfirex is offline   Reply With Quote
Old 09-03-2016, 10:18 PM   #2
billysvue
Default Re: Alignment Problems. Need help in the right direction
FInd an alignment shop that can check the 4W alignment, has been in business for a long time and has good reviews.
They ought to be able to diagnose it better than the last shop.
WHere R U?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 09-04-2016, 09:43 AM   #3
Saturn4Ever
Saturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the roughSaturn4Ever is a jewel in the rough
Saturn4Ever's Avatar
2009 Astra XR
After I replaced the shocks and struts on my other car, I just took it to my local GM dealer for a computerized alignment so it is aligned to spec...didn't take long and was about $100. You'll get a printout showing the before and after adjustment readings for camber etc.
2009 Saturn Astra XR, 140,000 km
2018 Chevy Traverse Redline 52,000 km
Past vehicles:
2000 Oldsmobile Alero, 220,000km - Sold
2008 Saturn Outlook XR 280,000 km - Sold
Saturn4Ever is offline   Reply With Quote
Old 09-04-2016, 05:11 PM   #4
xdarkxfirex
I'm located in hamilton ontario. I originally took my car to canadian tire, and when I got the safety done at a cheaper shop, the mechanic said canadian tire didnt do it right, because the steering rack was loose. When I just had the car, the toe was off and traction keep kicking on when I tried to adjust it at home without measuring it(Stupid me).
I did the same yesterday after using another camber kit I bought, now the traction light stay lit when the alignment is off, because it never kicks in. I've seen people do alignment as cheap as $40. Canadian tire charged me $100, and I went back to have them redo it for free 2 months ago. I tried today before the labour day weekend and they were totally booked. They couldnt even find out why it was bad. They wanted extra to install the bolts and extra to even look at why its off. I dont even trust brand name alignment bolts. I bought moog bolts with plastic inserts off amazon, and it said to torque to 100ft/lbs and snapped at about 70-80. I bought a generic brand 12mm bolt kit with 4 for about $17 off aliexpress with shipping. They are the same bolts ez cam uses.
For your alignment was the front caster off from the factory? Both of mines are off by 2-3degrees
Old 09-05-2016, 12:26 PM   #5
xdarkxfirex
After adjusting the toe at home by feel and measuring, I got it really close to where it was, and reset the traction control light. It needed three full turns on the left side to get it fairly close. Much better, but I still need a shop to adjust it more
Tags
alignment, camber, problem
Alignment problems cdxhizors S-Series Tech 17 04-03-2015 11:19 AM
wheel alignment problems jmarlo1 L-Series Tech 4 10-04-2008 08:44 AM
Rear A/C airflow direction and temperature problems... Carlucci Outlook General 0 05-01-2008 01:59 PM
Alignment Problems on 94 SC2 with 55K miles 94sc2 S-Series Tech 4 01-19-2005 12:05 AM
Alignment Problems ? John659 L-Series Tech 0 08-08-2001 10:20 AM
