Old 04-07-2015, 12:27 AM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Question Rear wheel alignment is possible in 2001 SL2
Local alignment shop said they are not sure if real wheel alignment is possible in saturn sl2 2001.
So I am asking experienced people here if its possible ...They said some cars you can't adjust rear wheel alignment as there is no adjustment that they can make....so is 2001 Saturn sl2 one of them?
also, what should I be concerned when they do the alignment? any latest software to be installed etc. please advice.
vikasevan is offline   Reply With Quote
Old 04-07-2015, 11:29 AM   #2
lamping.ap
lamping.ap will become famous soon enoughlamping.ap will become famous soon enough
Default Re: Rear wheel alignment is possible in 2001 SL2
Yes. Toe is adjustable where the lateral links meet the rear crossmember. Camber is adjustable via slotted holes (depending on your strut) where the strut assembly meets the knuckle.
EDIT: oops...just noticed you found the answer.
lamping.ap is offline   Reply With Quote
Tags
alignment
rear wheel alignment deanm S-Series General 2 08-09-2009 05:27 AM
Squeek from rear wheel well area, 2001 SC2? EricSaturnSC2 S-Series General 8 08-20-2008 02:38 AM
Rear alignment kit 2001 L Series btrautman L-Series Tech 0 05-01-2008 08:11 PM
rear wheel alignment necessary when replacing struts? boeing S-Series General 5 04-16-2006 10:25 PM
Wheel alignment on 2001 SC-1 triger S-Series Tech 2 04-17-2001 06:09 AM
