Old 05-21-2014, 01:52 PM   #1
kevster0522
kevster0522 has a spectacular aura aboutkevster0522 has a spectacular aura about
kevster0522's Avatar
Question Did I get a bad alignment?
Hello everyone I decided to conquer my weird unstable steering today and take a look under the car. I wanted to see if the subframe is misaligned from when I replaced it last year. The first two pictures show the alignment holes on the subframe. I feel like they are lined up almost perfectly (although the driver side hole is quite rusty). Then I took a look at my tires and found that the passenger side tire has uneven wear. The 3rd and 4th picture shows the driver side tire and the 5th and 6th pictures show the passenger side tire. It's kind of hard to see from the pictures, but there is significantly more wear on the outside of the passenger side tire. I got my alignment about a year and a half ago at fleet farm after I replaced the subframe. Do you think they did the alignment wrong or is this a different issue? How should I go about fixing this?
1995 sl1
kevster0522 is offline   Reply With Quote
Old 05-21-2014, 02:08 PM   #2
Default Re: Did I get a bad alignment?
Yes, this is an alignment issue.
http://www.saturnfans.com/photos/sho...ight/cat/12963
Verify ride height and have gas tank full and junk out of trunk.
All final as left settings to be at the preferred value. http://www.saturnfans.com/photos/sho...pecs/cat/12963
Order of Adjustment
  • First: Rear Camber
  • Second: Rear Toe
  • Third: Right Front Camber and Caster
  • Fourth: Left Front Camber and Caster
  • Fifth: Front Toe
If there is an imbalance in camber or toe across an axle then there is a resultant thrust angle that is not parallel with the centerline of the car. The rear really is adjustable without special tools.
Tags
alignment, steering, subframe, tire wear
New LCA gone bad after alignment rocket321 S-Series General 2 07-18-2013 07:52 PM
Tie rod end and alignment? 2002 sl1 S-Series General 13 03-04-2010 07:26 PM
'94 SC1 Alignment SLM crew chief S-Series Tech 1 07-14-2009 04:07 PM
Alignment ym42 S-Series Tech 11 02-14-2006 10:17 PM
ion alignment hemken Ion General 1 04-17-2005 06:20 PM
