Old 06-02-2012, 01:36 PM   #21
chilipepper1327
chilipepper1327 will become famous soon enough
chilipepper1327's Avatar
2006 ION-3 Quad Coupe
Default Re: Front end shaking, please help!
Originally Posted by trancer78 View Post
It wasn't a balancing issue. I'm not mechanically inclined but as he explained it, it was related to the tightening of the lug nuts. While they were tight, the wheels were not completely straight. I have aftermarket 18" rims and he mentioned said he finds spinning the wheel while tightening each of the lug nuts gives a more even fit.
End result, I took it on the highway and it drove perfectly and it cost me less than $40.
The lugs are designed to prevent issues like this. They are kind of conical, so that when you tighten them, they center themselves in the post hole.
Then only way this would not work is if the whole weight of the car was on the wheel even before it was tightened. Extremely doubtful...
chilipepper1327 is offline   Reply With Quote
Old 06-02-2012, 01:52 PM   #22
2006 ion2
2007 ION-2 Sedan
or, like I said, if something is at odds between the rim and the hub or car...
2007 Saturn Ion 2
2003 Chevrolet venture lt
alignment, shaking, steering, vibration, wheels
Front end shaking when brake is applied awilson506 S-Series Tech 10 03-07-2012 01:38 AM
front end shaking solarcar_sc1 S-Series Tech 9 03-05-2012 01:50 PM
Front end shaking RGK1168 S-Series General 4 12-19-2011 01:19 AM
front end shaking angel31 Vue Tech 5 06-29-2010 02:35 PM
Bad Front End Shaking at high speed jamman S-Series Tech 13 12-12-2006 09:31 PM
