Old 05-10-2006, 10:56 PM   #1
96 saturn
96 saturn is on a distinguished road
96 saturn's Avatar
Default ticking noise
1996 Saturn DOHC Manual Trans.
ok i have a ticking noise coming from the timing chain side(passenger side) The noise only happens under acceleration. I have no carpet in my car so i can hear the noise from the inside. My oil level is fine so its not that. Any ideas what it could be? I put it in neutral and reved it up slowly but no noise. IM LOST!!!
Best 1/8 mile 10.037@70.59
Add to 96 saturn's Reputation
Rate the quality of this post and help 96 saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
96 saturn is offline   Reply With Quote
Old 05-10-2006, 11:03 PM   #2
disel24
disel24 is on a distinguished road
Default Re: ticking noise
So it happens when you accelerate in gear but not when it's in neutral? Is that right?
Add to disel24's Reputation
Rate the quality of this post and help disel24 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
disel24 is offline   Reply With Quote
Old 05-11-2006, 12:59 AM   #3
96 saturn
96 saturn's Avatar
yes it happens while driving under acceleration. When parked and running i slowly reved it up in neutral and no noise.
Old 05-11-2006, 02:28 PM   #4
gmschrank
gmschrank is on a distinguished road
I would check suspension and drive axle components. Does the ticking happen while making turns, while going straight, or is it nondiscrimentory? Is there any correlation with the frequency of the ticks and what the car is doing (e.g. the ticks go faster when engine in reving faster)? Does it happen only under hard accelerations or any acceleration?
Add to gmschrank's Reputation
Rate the quality of this post and help gmschrank reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gmschrank is offline   Reply With Quote
Old 05-11-2006, 03:53 PM   #5
96 saturn
96 saturn's Avatar
nondiscrimentory. there is correlation with the frequency of the ticks and what the car is doing .the ticks go faster when engine in reving faster!! it happens under hard acceleration mostly but as soon as i let off the gas it stops. Turning has no effect on it. only the gas pedal seems to.
Old 05-11-2006, 09:16 PM   #6
DarrylLeeOHS30
DarrylLeeOHS30 is on a distinguished road
2001 SL2
my guess would be lifters ticking or the timing tensioner.
-Darryl
Add to DarrylLeeOHS30's Reputation
Rate the quality of this post and help DarrylLeeOHS30 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DarrylLeeOHS30 is offline   Reply With Quote
Old 05-11-2006, 10:17 PM   #7
96 saturn
96 saturn's Avatar
yea thats what im thinking. Either that or i spun a crank bearing. So im just going to look for a used engine. I found a place i can get one for $850. A rebuild kit cost about 1200$. Plus my engine has 150,000 miles with a rebuld never done. I bought it with 40,000 miles on it in 2000. The one thing that has gone right is i installed the header off a 92. Has to do some modifications to my rigged exaust but its all in workin order now. Sounds pretty good also.
Old 05-12-2006, 07:07 AM   #8
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
For what it's worth, have you checked your CV joint on the passenger side?
Add to jambra1's Reputation
Rate the quality of this post and help jambra1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jambra1 is offline   Reply With Quote
Old 05-12-2006, 07:04 PM   #9
Frank3
Frank3 is on a distinguished road
A spun crack bearing usually make a lot more noise than a ticking usually more like a knocking sound that is lower in tone.
Add to Frank3's Reputation
Rate the quality of this post and help Frank3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Frank3 is offline   Reply With Quote
Old 05-22-2006, 10:47 PM   #10
jhjc52
jhjc52 is on a distinguished road
If your noise is coming from whats seems like the top of the motor my money would be on the top timing chain guide, the plastic comes loose and makes a ticking noise.
Add to jhjc52's Reputation
Rate the quality of this post and help jhjc52 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jhjc52 is offline   Reply With Quote
Ticking noise ADickinson88@gm S-Series Tech 0 11-24-2006 11:52 PM
Ticking noise KatWoman S-Series General 15 03-17-2006 12:09 PM
Ticking Noise (Yes another one) DoctaJones S-Series Tech 13 09-01-2004 05:57 PM
What is that ticking noise? Aironwater L-Series Tech 2 11-21-2001 07:30 AM
ticking noise? lowrider SL1 S-Series Tech 14 11-11-2000 11:52 AM
