Old 01-24-2004, 03:49 PM   #1
dunnjf
dunnjf is on a distinguished road
Default Ticking noise in engine area
Have a 93 SC2 with 127,000 miles started hearing a ticking noise on the left side of the engine. Checked the exhaust looks good. Need some help on where it is coming from. Engine runs good, good idle and acceleration. Only here the ticking at idle, both inside and outside of car... Thanksfor any info!!!
Add to dunnjf's Reputation
Rate the quality of this post and help dunnjf reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dunnjf is offline
Old 01-24-2004, 03:59 PM   #2
amazinghl
Default Re: Ticking noise in engine area
How's your oil level?
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 01-24-2004, 04:39 PM   #3
dunnjf
Default
Oil level fine...uses about 1gt per 3000 miles. I check it once a week.
dunnjf is offline
Old 01-25-2004, 03:59 AM   #4
winc
winc is on a distinguished road
Default
how is the tension on the belts?
'95 SL1 auto (retired)
'02 RSX 5spd (her baby)
'05 WRX 5spd (my baby)
Add to winc's Reputation
Rate the quality of this post and help winc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
winc is offline
Old 01-25-2004, 09:40 AM   #5
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
Is the ticking noise regular or irregular? Regular would point towards lifters/cams, irregular would lean more toward timing chain.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 01-25-2004, 08:16 PM   #6
92saturnsl2
92saturnsl2 is on a distinguished road
92saturnsl2's Avatar
Default
Sure it's not the injectors? 1st generation low impedance injectors emit a noticable tick that slowly goes away as RPM is increased.
Add to 92saturnsl2's Reputation
Rate the quality of this post and help 92saturnsl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92saturnsl2 is offline
Old 01-26-2004, 03:15 PM   #7
dunnjf
Default
Noise is definitely coming from the front of engine(passenger side) pulled the oil cap off and diddn't here anything oulder sound. The sound is kinda erratic not regular. Sounds like marbles in a tin can rolling around. Going to pull the cam cover off and check the timing chain. Is there a gasket for the cam cover or just use RTV to form a gasket? Hopefully the timimg chain isn't loose.
Thanks again for the quick responses!!!
dunnjf is offline
Old 01-26-2004, 06:57 PM   #8
92saturnsl2
Default
Use RTV on the valve cover for 1991-1995 DOHC and all SOHC engines.
1996 and up DOHC engines with the composite covers require a preformed gasket.
Old 01-27-2004, 11:27 AM   #9
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
Default
My bet is on the timing chain.
Toyota: Moving Forward... off a cliff at a high rate of speed.
Add to K-1's Reputation
Rate the quality of this post and help K-1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
K-1 is offline
Old 01-27-2004, 11:37 PM   #10
geartooth94
geartooth94's Avatar
Default
...how about quarters clanking around in a drying machine?
If you search the boards, you'll find that's Wolfman's description of a failing timing chain.
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline
Old 02-05-2004, 11:31 AM   #11
Thalisa
Thalisa is on a distinguished road
Default
I have no idea if this was a problem in the S series or not, however, I had a similar noise on the same side of my 01 L200 and it was the evaportator purger bracket that was mounted in the wrong place. They got a newly designed bracket and remounted the thing somewhere else.
Add to Thalisa's Reputation
Rate the quality of this post and help Thalisa reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Thalisa is offline
Old 02-09-2004, 09:35 AM   #12
dunnjf
Default
Finally got the time to remove the Cam cover... Haven't been driving the car since the first post. looking down inside the timing chain cover, there it is about a 1 inch piece of the timing chain guide broken off and laying across the chain. So looks like new tming chain time... Roughly how long to change the chain, guides, and tensioner?
Also going to change the water pump. Anything else while I have the front cover off? Is this a common problem with the guide breaking off?
Thanks for all the responses great forum!!!
dunnjf is offline
Old 02-09-2004, 10:03 PM   #13
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
roughly a six hour job going by "book time" - count on the better part of a weekend if you haven't done one before.
Make sure you replace the chain, guides, tensioner and sprockets - using Saturn parts (available as a complete kit from a retailer). Also, make sure that you replace the two oil pump seals that reside in the block (they mate up with the front cover.
As far as other items, the water pump is not a bad idea, if it has not been changed in a while. Idler pulley and tensioner are cheap and easy to replace while you are there too...
Old 02-14-2004, 07:49 PM   #14
dunnjf
Default
Finally had time to tackle the timing chain. What mess when I got the front cover off. The right side guide was about 60% gone. The left side was still there, but with a serious wear groove. Boght the timing kit from Saturn and all is well now. Still need to drop the oil pan and clean it out due to wear of the guide. Thanks for all the help...Any tricks to removing the oil pan!!!
dunnjf is offline
chain-like noise comng from engine area. SWargy S-Series General 12 09-24-2008 07:47 PM
ticking noise 96 saturn S-Series Tech 9 05-22-2006 11:47 PM
noise in the engine area bill02awd Vue General 4 06-06-2005 11:07 PM
What is that ticking noise? Aironwater L-Series Tech 2 11-21-2001 08:30 AM
ticking noise? lowrider SL1 S-Series Tech 14 11-11-2000 12:52 PM
