Old 06-19-2010, 09:47 AM   #1
rollin_96
rollin_96 is on a distinguished road
1996 SL1
Default Cylinder Head Ticking
last night when I came to a stop at a red light, the head starting ticking. This morning I checked the oil it was almost full and looked fairly clean.
Would it be better to buy a rebuilt dohc head ($350), timming chain set , and a dohc pcm (junkyard pulls) and swap out the sohc head or swap my 94' dohc engine etc. in to the 96' sohc body? I easily got over $1200 invested, more parts then labor in the 96'.
Maybe I should just drop a jy dohc engine in? (450.00)
I kinda got a sentimental feeling for the 96'.
PO's idea of maintenance was, If it anit broke don't fix it.
She's my baby )
Tweaked FSM http://www.mediafire.com/?ofliygqpep460un
Add to rollin_96's Reputation
Rate the quality of this post and help rollin_96 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rollin_96 is offline   Reply With Quote
Old 06-19-2010, 11:50 AM   #2
rollin_96
1996 SL1
Default Re: Cylinder Head Ticking
What would be the best option? I'm thinking a newer sl2 for about 1500-2000 or should I just invest enough to get rollin again.
I original brought my 94 for a gas saver, vs my truck. But now i don't wanna give up on my 96' lil turd.
Old 06-19-2010, 02:59 PM   #3
Might be a bit easier and cheaper to find out what is causing the noise first. You may not have to do something as drastic as replacing the cylinder head.
Add to ssicarman's Reputation
1.9 SOHC Cylinder Head/Head Gasket..... Coolant Leak BRIAN41920 S-Series Tech 12 01-21-2014 02:40 PM
Blown head gasket...vs....cracked cylinder head?? schultp S-Series Tech 1 06-25-2007 10:16 PM
SL1 'ticking' just replaced head, rings, oil pump saturnhouse S-Series General 9 03-09-2006 09:37 PM
95 SL1 Cylinder Head dgcampbell1 Ion General 1 06-14-2004 04:04 PM
Cylinder head wingnut Miscellaneous Tech 3 11-21-2002 11:11 PM
