Old 07-03-2006, 12:57 PM   #1
slo5.0
slo5.0 is on a distinguished road
Default Do I need the exhaust resonator???????
My wife drives a 99 SC2 and the exhaust resonator is now leaking around the crimps. What would happen if I removed the resonator completely and replaced it with a piece of pipe?? How loud would it be and would I lose any low rpm torque due to loss of back pressure??
Thanks for any insights,
Brad
Add to slo5.0's Reputation
Rate the quality of this post and help slo5.0 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slo5.0 is offline   Reply With Quote
Old 07-03-2006, 01:05 PM   #2
wolfman
wolfman's Avatar
Default Re: Do I need the exhaust resonator???????
"Need?" NO. IF removed, both the tone and volume of the exhaust will be affected. (Louder and "harsher") The resonator is not expensive to replace and either it OR a simple length of exhaust pipe must be welded in place. Just take it to a muffler shop and be done with it.
Add to wolfman's Reputation
Old 07-03-2006, 01:10 PM   #3
Tiger
Tiger's Avatar
My 99 SL2 had two of them replaced before I purchased it. There is a TSB explaining why they leak. When I posted about it years ago, some one said a muffler shop welded the leaking area for about $20. That may be an option to look into, if the rest of it is good.
Here is link where I talked about the info. I have the TSB somewhere.
http://www.saturnfans.com/forums/sho...ight=resonator
Add to Tiger's Reputation
Old 07-03-2006, 01:35 PM   #4
thawk
thawk is on a distinguished road
I cut my resonator off about 2yrs ago and clamped a piece of straight pipe in there. The exaust is a little louder but not bad. I've noticed no performance degradation
Add to thawk's Reputation
Rate the quality of this post and help thawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
thawk is offline   Reply With Quote
Old 07-03-2006, 05:22 PM   #5
slo5.0
Thanks for the replies. I had planned on just having them repair the existing resonator. If they won't agree then I'll have them weld in a piece of pipe.
Thanks again,
Brad
Old 07-04-2006, 12:03 AM   #6
eRic 02sc2
eRic 02sc2's Avatar
replacing the resonator with a straight pipe would make the exhaust sound louder and raspier. you'll really hear it when you rev past 4000 rpm.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 07-04-2006, 12:59 PM   #7
slo5.0
thanks again for the advice. I tried to get it welded up yesterday but every place was closed. I'll try again on Friday.
Old 07-04-2006, 11:37 PM   #8
The exhaust may tend to backfire a bit on decel. It depends on the size of the cat converter. The 2000 Sl's had this problem due to a smaller converter. The repair was to install a resonator. Instead of a straight pipe go for a bottle resonator.
Add to ssicarman's Reputation
Old 07-10-2006, 07:30 PM   #9
slo5.0
Again thanks for the replies. The crimps on the resonator could not be welded up very easily so I opted to replace the resonator with a length of pipe. The job cost me $40+tx (wish I owned a welder!). I could have spent $75+tx to replace it with a glasspack but decided to save some money.
The car sounds perfectly stock unless it is revved above 3500-4000 rpms where is becomes raspy (very accurate eRic 02sc2). This of course is not an issue since my wife drives it and its an automatic.
124k and counting...
Old 07-10-2006, 07:34 PM   #10
itsmesillybubba
itsmesillybubba is on a distinguished road
itsmesillybubba's Avatar
2006 ION-3 Quad Coupe
WhereI live...It is illegal to put a resonator on a car that is a 95 or newer.....if it rusts out...the shop has to, by law, put in another cat...if you have a resonator on a 95 or newer car it will fail inspection.
Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.
My 95 SL1 is gone :(
Add to itsmesillybubba's Reputation
Rate the quality of this post and help itsmesillybubba reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
itsmesillybubba is offline   Reply With Quote
Old 07-10-2006, 08:06 PM   #11
Uzzy
Uzzy's Avatar
2002 SC1
That is one of the stupidest things I've ever heard.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 07-10-2006, 08:09 PM   #12
slo5.0
If it fails (although doubtful), it fails. I'll deal with it then.
Old 07-10-2006, 10:10 PM   #13
itsmesillybubba
you are right...it's stupid
Old 07-10-2006, 10:18 PM   #14
wolfman
wolfman's Avatar
You are perhaps confused...the OEM resonator is used WITH a catalytic convertor not in place of one and is replaced if necessary in ADDITION to the OEM convertor, not as a replacement for it.
Old 07-11-2006, 09:35 AM   #15
itsmesillybubba
But when the cat goes...a lot of people just put another resonator in there....you are allowed to if your car is older than a 95, if it is newer you have to buy a new cat. you cannot substitute another resinator
Old 07-11-2006, 09:40 AM   #16
Uzzy
Uzzy's Avatar
2002 SC1
What? No if your cat goes, you have to replace it with another cat, no matter what the year. Maybe it's different out east, but I thought it was Federally mandated, not provincially. I thought you meant if the resonator goes you need to put on a second cat in it's place, which is stupid.
Old 07-11-2006, 09:46 AM   #17
itsmesillybubba
What? No if your cat goes, you have to replace it with another cat, no matter what the year.........
If I had a 94 and the cat went...I would be allowed to put a resonator in its place.....if I had a 95 and the cat went...I would have to put on another cat.....thats how the law works here.
Old 07-11-2006, 10:00 AM   #18
Uzzy
Uzzy's Avatar
2002 SC1
Well over here (and every where else I know of) my '85 S-10 had a plugged up cat. It's exempt from emmissions testing, but the hollowed out catalytic convertor I put in there is illegal (shhhh ) If it had one originally it still has to have one. I've never heard of it being different anywhere else.
Old 07-11-2006, 10:06 AM   #19
itsmesillybubba
Us Maritimers must be stupid or something I am glad we do not have emmision testing here.....I have had sooo many crappy cars that would not have passed.
Old 07-11-2006, 10:07 AM   #20
Uzzy
Uzzy's Avatar
2002 SC1
I'm just not gonna say anything about that.
Exhaust Resonator whitebluesc2 S-Series Tech 5 08-25-2009 09:12 AM
Exhaust resonator and MPG slv01sc2 S-Series General 10 04-06-2006 09:27 PM
Exhaust resonator slv01sc2 S-Series General 5 02-20-2006 12:22 AM
Exhaust Leak Behind Resonator DualCamCoupe S-Series Tech 4 02-07-2005 12:27 PM
Exhaust Resonator SL2Dreams S-Series General 1 09-29-2003 11:31 AM
