Old 06-23-2012, 09:10 PM   #1
Loanshark
Loanshark is on a distinguished road
Default 2002 SL1 sounds like someone strangling a cat.
I usually pretend there's and egg between my foot and the excellerator. But today I pressed a bit harder than normal going up a hill. The car downshifted and the engine sounded bad... The sound is hard to describe... Didn't seem to make much more power with the higher RPMs... What do the experts reccomend I check first?
2002 SL1 SOHC auto 208k miles and counting.
Add to Loanshark's Reputation
Rate the quality of this post and help Loanshark reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Loanshark is offline   Reply With Quote
Old 06-23-2012, 10:43 PM   #2
magtec
magtec will become famous soon enough
1995 SW2
Default Re: 2002 SL1 sounds like someone strangling a cat.
can you record the noise for us?
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 06-23-2012, 11:09 PM   #3
Loanshark
I can try. Dunno if it will be picked up...
Old 06-25-2012, 12:01 PM   #4
mansaturn
mansaturn is on a distinguished road
cat-strangling whine that varies with engine rpm can often be low trans. fluid. check the trans. fluid level immediately. if it is low, and you must drive it, at least fill it to the proper level so you don't burn up the trans. find the leak (usually the external spin-on filter needs to be replaced), and fix it before driving.
Add to mansaturn's Reputation
Rate the quality of this post and help mansaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mansaturn is offline   Reply With Quote
Old 06-25-2012, 04:54 PM   #5
Loanshark
The fluids are all good, and I haven't been able to reproduce the sound... I had an 83 ford escort with 68hp that wasn't much worse at maintaining speed going up a slight grade... What should I be checking?
Old 06-27-2012, 10:10 AM   #6
mansaturn
there is an odd appropriateness to your description. if your trans. fluid is definitely not low, you might have a partially clogged cat (catalytic converter). the blockage in the exhaust can cause an unusual sound, and the car will often run ok under low rpms and loads, but stumble or fall flat or lose power when
accelerating harder.
Old 06-27-2012, 10:40 AM   #7
Loanshark
I thought of that after I typed it in. I said to myself they're gonna tell me that my cat is strangling my engine...
With the high miles I'm leery of mashing the pedal, so how do I check the condition of my cat? Should I just remove it? Cash is tight so I'll be looking for a cheap fix if there is one...
Old 06-27-2012, 10:47 AM   #8
madpogue
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
1996 SW2
Quickest test - remove (don't just unplug, but REMOVE) the front oxygen sensor from the exhaust manifold. Take it for a short, LOUD drive. The sensor is just coincidental; all you're doing is providing an alternate exhaust path (think of it as an emergency tracheotomy). If performance improves, that suggests a restriction.
Your car being a 2002, does it have a pre-cat? Look at the exhaust manifold; if it looks like it swallowed a whole can of ham, it has the pre-cat. And that's the one that is most often the clogged one. You can gut it out without any impact on the engine's operation (and it won't set a code).
Add to madpogue's Reputation
2002 Saturn Vue: Popping sounds while turning DugoutBlues Vue General 10 03-24-2009 01:23 PM
sounds like cai? coolvue Sky Mods 5 11-18-2008 01:00 PM
Sounds. Here's a fun one. jserbay S-Series Tech 10 09-15-2006 09:10 PM
2002 Vue keeps quitting! Sounds like it's not getting fuel.. Marquita Vue Mods 5 07-25-2006 11:41 PM
