Old 10-15-2018, 08:38 PM   #1
Charbear
Charbear is on a distinguished road
Default Another Vue A/C Issue
I have a nice 2008 Vue (high mileage but great condition). I've seen similar issues mentioned in this great forum but I have not yet found one with a good solution. I do have slightly different details than I've seen and my situation is inconsistent...but consistent (weird, huh?). Fortunately, this only happens about once ever 4-6 weeks. However, when it happens, the pattern has been consistent. I would appreciate an input on how to diagnose/troubleshoot the possible culprit (ECU needs reprogramming, needs new climate control panel, needs new temperature sensor, etc.). So far, every time the issue has happened, this has been the situation. I'm in FL so it's been hot. Outside temp registered in the car looks OK.
Drive car 30-60 mins (A/C working). Park car for 6-8 hours. Start driving again. A/C works for ~10mins then quits. Fan still blows. Air flow automatically switches from recirculate to outside flow. Light is still on A/C switch. Push switch on/off. Light on dial flashes. Recirculate button flashes then goes back to outside flow. Drive home hot. Park car overnight. Start car next day. No A/C. After driving about 5mins, A/C comes on. Might work fine for 4-8 weeks, then it happens again.
Thoughts on what it is? How to diagnose/fix. I'm not an A/C guy but I can work on cars (remove and replace components mostly). If it's most likely something cheap like an outside temp sensor, I'll just replace it and hope. If it's most likely a $250-$500 climate control panel, I'd like to really make sure it's the issue before I replace it.
Suggestions/feedback/help greatly appreciated.. Thanks!
Add to Charbear's Reputation
Rate the quality of this post and help Charbear reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Charbear is offline   Reply With Quote
Old 10-15-2018, 10:57 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: Another Vue A/C Issue
I'm probably wasting your time but I located four HVAC service bulletins which appear to address your issues to some extent.
Common to all the bulletins is need for dealer to reprogram AC control module.
The files are too large to attach but I can email ... PM an address if you're interested.
I try to visit forum daily but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
03 Vue anti theft issue and ignition issue jamil0810 Vue General 4 07-17-2012 02:43 PM
Abs Light issue, ive searched and repaired still an issue. mudawg Vue Tech 11 03-21-2012 12:15 AM
tensioner issue/belt issue recurveman S-Series General 2 06-27-2011 10:35 PM
3.0L Oil Cooler issue NOT fixed & steering issue Partymmudasti L-Series Tech 5 08-08-2008 09:48 AM
steering wheel issue??suspension issue?? i'm dumbfounded VTVUE Vue General 8 06-17-2008 07:54 AM
