Old 05-14-2006, 01:53 PM   #1
357kevin
357kevin is on a distinguished road
Default Oil Pan
Hi all, I have a 1992 SL1 1.9 sohc that has a rusted through oil pan. My question, is it a difficult job to replace the oil pan for someone who does not work on cars a whole lot? Also, are there any other parts i should replace while doing this such as oil pump? I am the original owner of this car which has about 165,000 miles on it. I am just trying to keep it going for about another year or so therefore don't wan't to put too much $ into it. All comments are appreciated. Thank you!!
357kevin is offline   Reply With Quote
Old 05-14-2006, 01:58 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Oil Pan
You have to remove part of the exhaust system to get to the oil pan in addition to some other bits that are in the way. It's probably not something you want to attempt if you don't work on cars much. Talk to a local Saturn tech and see if they can help. Here are instructions
http://www.autozone.com/servlet/UiBr...3d80199ae0.jsp
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 05-15-2006, 01:19 AM   #3
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Default Re: Oil Pan
Yeah, if you arent very confident in yourself, you might want to find a tech to do it on his lunch break.... It involves unbolting and moving your exhaust, removing the crank pulley, and must clean ALL of old gasket off of bottom of block......
Old 05-15-2006, 05:29 PM   #4
Jeff K
Jeff K is on a distinguished road
Jeff K's Avatar
1992 SC2
Default Re: Oil Pan
I had the same problem and couldn't afford $100 canadian for an oil pan. Heres my fix should work for a year or more if done right. I drained all the oil from my saturn cleaned all the grease off the pan with brake cleaner and a rag, then I cleaned all the rust around the rust hole with 40 grit sandpaper until shiny and cleaned the area again with brake cleaner, then I mixed up a small amount of JB weld and applied it with a bodyfill spreader over and around the hole, just make sure you clean to bare metal around the hole where the JB is applied. I built the JB weld out about 1/8". Then let the weld drie for about 15 hours before adding oil or starting your engine. I sprayed mine with truck bedliner the day after. Its hasn't leaked a drop in since I fixed it over 2 weeks ago and thats with synthetic oil. This fix only cost me about $12 and I didn't have to drop my exhaust.
Jeff K is offline   Reply With Quote
Old 05-16-2006, 07:43 PM   #5
357kevin
Default Re: Oil Pan
Thanks for all the suggestions guys. I really like Jeffs J/B Weld idea, i think i'll try it. I called around for quotes to have it replaced and was surprized that the pan only cost $56.00 from the Saturn dealer, they wanted $375.00 for parts and labor.
Old 05-16-2006, 08:02 PM   #6
firevswater5
firevswater5 is on a distinguished road
Default Re: Oil Pan
I have a rust spot starting on my '99 Sl2 oil pan. Should I sand it down and put a fresh coat of paint over it or just let it go?
firevswater5 is offline   Reply With Quote
Old 05-16-2006, 08:30 PM   #7
Jeff K
Jeff K's Avatar
1992 SC2
Default Re: Oil Pan
I would let it go you'll probably never win maybe spray the oil pan down with some rust check I am a firm believer in undercoating.
Old 05-23-2006, 03:12 PM   #8
357kevin
Default Re: Oil Pan
Hey guys, just to let you know, i tried the J/B Weld idea and it seems to be working so far. I sanded it down and cleaned it with brake cleaner and applied the J/B Weld and so far no more leak however i don't know how long it will last, the pan was slightly better than paper thin in some spots, i took a drill bit and pushed it through with very little effort. Time will tell. Thanks again for your help!
Old 05-23-2006, 03:46 PM   #9
GreenSC2
GreenSC2 is on a distinguished road
GreenSC2's Avatar
Default Re: Oil Pan
Since it is not leaking at this point, a thick layer of spray on undercoating might help to keep it from being damaged from stone chips and other junk being thrown on it from the road.
It's not easy being Green(SC2). (IntelliTXT SUCKS)
I refuse to be a Lemming!!
GreenSC2 is offline   Reply With Quote
Old 05-23-2006, 04:31 PM   #10
eljefino
eljefino's Avatar
1995 SW1
Default Re: Oil Pan
I would start saving up for a new pan there Kevin.
Old 05-23-2006, 05:34 PM   #11
tmaugham
tmaugham is on a distinguished road
1997 SW2
Default Re: Oil Pan
Is this a frequent problem with Saturns? We (me and various family members) have had a variety of Saturns from 1991 through 1999 and have never experienced this. I've never noticed any rust at all on my oil pans when doing oil changes.
tmaugham is offline   Reply With Quote
Old 05-23-2006, 08:49 PM   #12
357kevin
Default Re: Oil Pan
This car has been good to me but it's getting to the point where i have to weigh cost vrs. life expectancy, i could put $360.00 into the oil pan problem and then six months later the trans could go out. It's like having an old pet that is dying, how much money am i going to spend on something thats going to die soon anyway. I might just break down and buy a new car soon and give this car to my 16 year old niece, her dad is a mechanic so he can fix it properly for her. At 14 years old and 165,000 miles i would say that was $12,000 well spent.
Cahnging oil pan, where can I get new pan bolts? SUPERCHARGE S-Series Tech 3 07-13-2009 04:04 PM
Oil Leak? Not oil pan, not valve cover, not front oil seal. klcl S-Series Tech 14 10-05-2007 12:25 PM
2003 AWDV6 fluid seepage at tranny pan & oil pan mysaturnvue2 Vue Tech 9 02-16-2005 08:10 AM
Burning a Quart of Oil Per 1500 miles: Oil Pan gasket or Rings? TIMSPEED Miscellaneous Tech 4 07-24-2004 09:06 PM
advise on oil....ls2's oil drain pan valve juliansdad L-Series General 6 07-31-2003 10:42 PM
