#1 |
![]() Join Date: Aug 2005
Found the bolts loose on my oil pan and tightened up the ones I could reach. I can't reach the ones on the passenger side of the motor. Anyone know if they can be reached if I pull the pass. side splash shield off? Or any other tricks I could try? Thanks.
#2 |
yes you pull the splash shield off and also the crank pulley.
Put a 21 mm socket on a breaker bar, brace this on the ground under the bumper, then go in and turn the key to start a couple times. the starter will spin the crank bolt off. Also removing the top axis mount and jacking underneath the oil pan will buy you some space. If removing the oil pan you can put a chunk of 2x4 under the passenger lower dogbone for support instead. |
Bookmarks |
96 SL1 oil pan change - grandma's car | Guvner | S-Series Tech | 23 | 12-16-2012 11:31 PM |
2001 Saturn SL1 oil pan gasket leak | jcm22 | S-Series Tech | 6 | 09-12-2009 03:05 PM |
Cahnging oil pan, where can I get new pan bolts? | SUPERCHARGE | S-Series Tech | 3 | 07-13-2009 04:04 PM |
need metric size of oil pan bolts for 97 sc2!! help, wife tossed them out!! | travman514 | S-Series Tech | 3 | 09-11-2006 10:32 AM |
2003 AWDV6 fluid seepage at tranny pan & oil pan | mysaturnvue2 | Vue Tech | 9 | 02-16-2005 08:10 AM |
