Old 06-30-2005, 11:46 PM   #1
Tom92SCm
Tom92SCm's Avatar
2004 VUE 2.2L
Default Axle Seals
Is there something suppose to go between the axle seals and the transmission case? I put in one set a week ago and it leaked again. I greased up the lips with some bearing grease but that was it. I thought I read something somewhere about Loc-Tite. Anything else? I couldn't find the Loc-Tite.
--Tom
Not a Saturn.
Old 07-01-2005, 12:01 AM   #2
Default Re: Axle Seals
You can put anaerobic sealant on the outer edge (basicly between the seal and the trans case) of the seal to prevent any leakage there. I believe that GM calls it gasket maker. I am sure that loctite would have it as well. Looks like a nice edible red liquid cherry gel. Thin layer on the outside edge of the seal would do the trick.
Old 07-02-2005, 10:54 AM   #3
Razorbak
Razorbak's Avatar
Loctite 515 (Anaerobic) Gasket Eliminator / Flange Sealant...
http://www.saturnfans.com/forums/att...achmentid=3539
Permatex (used to be part of the same company) makes an equivalent anaerobic product, but it comes in a blue tube. Can't recall the part number.
Razorbak is offline   Reply With Quote
Old 07-02-2005, 11:17 AM   #4
dcp
dcp is on a distinguished road
dcp's Avatar
I just did drivers side used the blue permatec ever so slightly ,on the metal edge of seal.Make sure you put the retainer clip back in front of the seal,that way you know the the seal is in far enough
dcp is offline   Reply With Quote
Axle seals MikeNW S-Series Tech 3 04-20-2008 08:30 AM
Should I replace axle seals? cincy_14 S-Series General 13 04-17-2008 12:40 AM
axle seals our1vue Vue General 5 03-10-2006 09:14 PM
Axle seals leaking still - Applefool Miscellaneous Tech 8 10-06-2003 04:03 PM
Axle Seals.. Applefool Miscellaneous Tech 2 07-03-2003 12:25 AM
