Old 03-15-2008, 01:54 PM   #1
cincy_14
cincy_14 is on a distinguished road
cincy_14's Avatar
Default Should I replace axle seals?
I'm in the middle of replacing the clutch on my 98 SL2 and I'm pondering wether I should replace the axle transmission seals since I have the axles out. The car has 150k miles, can you tell by looking at them if they're going bad? Also there is red dust on the back of the knuckle/wheel bearings, is that bad?
I've gotten alot of great info about replacing the clutch from this site, thanks to all the regulars!
cincy_14 is offline   Reply With Quote
Old 03-15-2008, 04:06 PM   #2
rc1488
rc1488's Avatar
Default Re: Should I replace axle seals?
I guess this weekend is clutch weekend
Many members say to replace the seals when you redo the clutch. I personally did not. Ive had no problems so far
Red dust....i wanna say thats just rust mixed with brake dust
Old 03-15-2008, 09:37 PM   #3
lexinva
lexinva is on a distinguished road
lexinva's Avatar
1996 SL1
CLUTCH WEEEEEEKKKKKEEEEENNNDDD!!!!!! Yeah!!!
Actually, I'm doing mine this weekend in honor of St. Patrick's Day. (car is green, get it?)
lexinva is offline   Reply With Quote
Old 03-15-2008, 09:48 PM   #4
hit_n_run
hit_n_run is on a distinguished road
LoL. No that was LAST weekend for me. This weekend, I'm installing OEM foglights on my SL2. There's more to it than I thought, though this forum is an absolute WEALTH of knowledge.
hit_n_run is offline   Reply With Quote
Old 03-17-2008, 12:52 PM   #5
amazinghl
I'd change it personally, if it hasn't been changed.
$10 seal and 5 minute now can save you $10 and 2 hours later on.
00 Insight 72mpg
Old 03-18-2008, 10:23 AM   #6
cincy_14
cincy_14's Avatar
I didn't change them since they looked to be in good condition. I filled the transmission to check for leaks after I put the axles back in but before I put the knuckles back together. I was concerned I'd just make more work for myself if I had trouble replacing them properly.
As for the red dust, I found some threads that say it means my wheel bearings are dying, but they turn without any noise or movement so I don't know.
The only problem I have now is the clutch pedal is soft. It shifts better than before because the pressure plate was WAY worn down, but it's not perfect. I know I probably have some air in the hydraulics, but I'm gonna try to get the air out before replacing them since they are only a few months old.
Old 03-18-2008, 11:27 AM   #7
rc1488
rc1488's Avatar
If the hydraulics are only a few months old then there shouldnt be a problem with air in the system
Old 03-18-2008, 11:40 AM   #8
cincy_14
cincy_14's Avatar
I don't know what else would make such a big change in how firm the clutch pedal is. I've read that it is possible for air to find it's way to the slave cylinder if it's not kept below the reservoir. But I'm a little confused how that could happen if the cap is not removed and it's a closed system.
Does a new pressure plate make it feel different?
Old 03-18-2008, 11:42 AM   #9
rc1488
rc1488's Avatar
Most definetly. I think your just not used to how smooth and easy it is to push the clutch with the new plate
Old 03-18-2008, 11:50 AM   #10
cincy_14
cincy_14's Avatar
Well it's still a little difficult to get into gear with the engine running, which makes me the think the clutch is not fully disengaging. I'll have to measure the fork travel when I get the time.
Thanks
Old 03-18-2008, 12:22 PM   #11
rc1488
rc1488's Avatar
Thanks
Thats a different situation haha
Definetly measure the fork travel. Also, Mobil 1 synthetic ATF fluid has had good results for better smoother shifting.
Old 03-18-2008, 08:56 PM   #12
virnin
virnin is on a distinguished road
virnin's Avatar
My brake pads (Hawk ceramic) give off reddish brown dust. I would change but the stop the car like nobody's business!
virnin is offline   Reply With Quote
Old 03-20-2008, 10:36 AM   #13
BarnOwl
BarnOwl's Avatar
I gotta tell you guys something. I just replaced the axle seals on a 5-Speed last night and it's a PITA even with the transmission out of the car on the garage floor. I wouldn't want to attempt it with the tranny in the car. If they are okay, I say leave them alone.
Oh and if you must, don't forget that there's a snap ring on the driver's side seal that you won't notice unless you know it's there.
Old 04-17-2008, 12:40 AM   #14
acemueller
acemueller is on a distinguished road
1998 SL
1992 SL2
I've been looking through posts on trans-to-axle seals, and have seen a couple of common themes. I have a 5 speed manual '92 SL2. I"ve replaced the clutch twice, never replacing the seals. Now I suddenly (within the past 2 weeks - 5 months since the last clutch replacement) have a rapid drip. I haven't gotten it up on blocks yet, but it looks like it may be coming from the drivers side axle - it is above the bottom edge, but low enough that the fluid had drained well off the dipstick, and has reached the point where you can see a drop every two or 3 minutes.
So, the question: Several posts mention the snap ring as being very subtle. If it is so hard to see, is there a particular trick to getting it out?
The other thing more than one post has mentioned is that it is a PITA to get out and in; is it at least doable with typical tools if I'm patient?
Thanks for any thoughts!
Thomas.
acemueller is offline   Reply With Quote
Axle seals MikeNW S-Series Tech 3 04-20-2008 08:30 AM
axle seals our1vue Vue General 5 03-10-2006 09:14 PM
Axle Seals Tom92SCm S-Series Tech 3 07-02-2005 11:17 AM
Axle seals leaking still - Applefool Miscellaneous Tech 8 10-06-2003 04:03 PM
Axle Seals.. Applefool Miscellaneous Tech 2 07-03-2003 12:25 AM
