#1 |
![]() Join Date: May 2009
1993 SL2
Hey peeps, changing the oil pan in my Saturn as it's rusted through, but after taking it off I'm noticing that many of the bolts no longer seem to be reliable enough to last a long time without stripping next time they have to be used.
Do the bolts usually come with a new oil pan? If not, where can I get some new ones? And ugh... how much am i looking at? 5$ a bolt? Thanks! |
#2 |
I'd be surprised if they weren't standard M6x1.0 bolts. But since they're steel, going into aluminum, you're more likely to strip the threads on the block than on the bolts. If you're worried about ROUNDING (not stripping) the heads, use a 6-point socket.
#3 |
1993 SL2
My bad, I did mean round off the heads. The problem is that they're very rusty. Although they may work now, I fear for later. Would finding regular stainless steel bolts be advisable or would they be too weak for even the low torque specs.
#4 |
I'd use stainless on mine if i had to and anti-sezie
that's balla-rific! |
Bookmarks |
Oil Leak? Not oil pan, not valve cover, not front oil seal. | klcl | S-Series Tech | 14 | 10-05-2007 12:25 PM |
need metric size of oil pan bolts for 97 sc2!! help, wife tossed them out!! | travman514 | S-Series Tech | 3 | 09-11-2006 10:32 AM |
Oil Pan | 357kevin | S-Series General | 11 | 05-23-2006 08:49 PM |
Reaching Oil Pan Bolts 92 Sl1 | johnt671 | S-Series General | 1 | 04-30-2006 04:20 PM |
2003 AWDV6 fluid seepage at tranny pan & oil pan | mysaturnvue2 | Vue Tech | 9 | 02-16-2005 08:10 AM |
