Old 11-09-2005, 04:38 PM   #1
RobertGary1
Default Throttle body cleaning
I'm still not understanding how to search the wonderful How-to-Library. Is there anything in the library on cleaning the Throttle Body? I'm sure I'm not the first person to need to do this.
RobertGary1 is online now   Reply With Quote
Old 11-09-2005, 05:10 PM   #2
andyr13
andyr13 is on a distinguished road
2004 VUE 2.2L
Default Re: Throttle body cleaning
I thought there was a "How-To" on here somewhere but I can't seem to find it anywhere either.
Some people here I have read just take the air intake off and simply spray carb cleaner into the TB. I have not tried this, mine was pretty dirty so I opted to take it completely off and clean it.
If my memory serves me correctly there are 2 bolts that hold the TB on. Take the air intake assembly apart and remove it, then take the 2 bolts out to detach the TB. There are a few connectors you have to disconnect on the TB itself, but after that it just comes right off. After I had it off, I took the 2 sensors (IAC, TPS) off and used about a whole can of carb cleaner on the TB.
Add to andyr13's Reputation
Rate the quality of this post and help andyr13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
andyr13 is offline   Reply With Quote
Old 11-09-2005, 05:17 PM   #3
cazzylee
cazzylee is on a distinguished road
cazzylee's Avatar
Pull the air intake manifold off, there's 2 10mm bolts. Get a gasket or you'll have a problem like me and be hunting all around because of a strange idle and no visible flaws to the gasket. Pull off the wire, pull the throttle, and there you go. Spray that sucker with some carb & choke cleaner until clean and pretty. Install is the reverse of removal.
It's not good to just spray the C&C into the throttle for a multitude of reasons.
Madness takes it's toll: Please have exact change.
SES light + unplugged sensor = testicle ownage.
Add to cazzylee's Reputation
Rate the quality of this post and help cazzylee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cazzylee is offline   Reply With Quote
Old 11-09-2005, 05:19 PM   #4
andyr13
2004 VUE 2.2L
My statement above might be wrong then. I thought some people sprayed carb cleaner right into the TB w/ the engine running. Maybe I read something wrong? Or do they use something else?
Old 11-09-2005, 05:40 PM   #5
dansl2
dansl2 is on a distinguished road
dansl2's Avatar
2000 SL2
On my 2K, there are 4 bolts, but I think earlier models only two. Disconnect the two electrical bundles, the vacumn lines, & the throttle cable (all really easily done). When you remove it, be careful you don't tear the gasket, or you'll have to see the dealer for that. Remove the IAC,(you'll need a torx drive for this,don't remember size)-careful not to loose that gasket either- & then spray the heck out of the body with carb cleaner. Use an old toothbrush to scrub off the stubborn carbon & make sure you spray out the access ports. Also spray the AIC pintle & spring to get all the carbon off there too. Don't mess with the pintle, as it should be in the retracted position & if it extends it can be a bear to get back on the TB. Spray the outside of the TB also to make sure there isn't any grung binding the throttle spring. Reassemble & replace. Should be good to go. You may want to use contact cleaner on the electrical connectors & some dielectric grease on them before reattaching.
Experience is something you don't get until just after you need it.
Add to dansl2's Reputation
Rate the quality of this post and help dansl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dansl2 is offline   Reply With Quote
Old 11-09-2005, 07:24 PM   #6
FL_SL2
FL_SL2 is on a distinguished road
They are T-20 torx screws holding the TPS and IAC on. Or, at the very least, I was able to use a T-20 driver to remove and replace them.
...if Despotism failed only for want of a capable benevolent despot, what chance has Democracy, which requires a whole population of capable voters. -- George Bernard Shaw 1903
Add to FL_SL2's Reputation
Rate the quality of this post and help FL_SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FL_SL2 is offline   Reply With Quote
Old 11-09-2005, 07:41 PM   #7
dansl2
dansl2's Avatar
2000 SL2
Actually, the best part about the whole proceedure is when you talk about it afterward, you can use "throttle body" & "pintle" in a conversation (ie; " I gave my throttle body a good cleanin' this afternoon & paid particular attention to my pintle) & not be obscene...it just sounds that way!
Old 04-08-2015, 06:10 PM   #8
Roccero
Roccero is on a distinguished road
Default Re: Throttle body Screws
Need some quick info I took the throttle body of my 97 Saturn SL2 and managed to drop the upper screw and cannot find it can someone tell me the size of this screw so I can replace it. Size and length would be great !!!
Add to Roccero's Reputation
Rate the quality of this post and help Roccero reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Roccero is offline   Reply With Quote
Old 04-08-2015, 07:58 PM   #9
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
I'd just take the remaining bolt to the hardware store and match them up.....My local ACE has a great selection of bolts etc.....
Throttle Body Cleaning Vs. Fuel Injection Cleaning TXSaturn02 S-Series Tech 7 05-28-2008 03:56 PM
cleaning the throttle body redcannon S-Series Tech 8 01-29-2008 01:59 AM
Throttle Body Cleaning? LotusLord S-Series Tech 2 09-25-2007 06:43 PM
throttle body cleaning justVUEit S-Series Tech 8 06-10-2006 08:39 PM
Throttle Body cleaning? llamakc S-Series Tech 3 02-05-2005 01:13 PM
