Old 11-11-2008, 01:48 PM   #1
funk53daba
funk53daba is on a distinguished road
Default coolant sensor vs. coolant sender
All right, so what I've gathered is my 95 SC2 has two parts that look practically identical...one is the coolant temperature sender, the other is the coolant temperature sensor. One of them affects my gauge reading in my dash. The sensor has two wires going to it, it's the one closest to the ground, and it's the one people refer to as the ECTS. All that correct?
1995 SC2, manual. 139k. 38mpg.
Some dude: "My windshield washers aren't working."
Forum: "Change your ECTS."
Add to funk53daba's Reputation
Rate the quality of this post and help funk53daba reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
funk53daba is offline   Reply With Quote
Old 11-11-2008, 01:57 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: coolant sensor vs. coolant sender
The two wire sensor is what sends temperature information the PCM and controls how the engine functions. Its the one closer to the bottom of the head.
The one wire sensor sends temperature information to the gauge on the cluster.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 11-11-2008, 05:59 PM   #3
aa4lr
aa4lr has a spectacular aura aboutaa4lr has a spectacular aura about
1995 SC1
Question Re: coolant sensor vs. coolant sender
Here's a stupid question -- why is it that the ECTS fails so catastrophically in older Saturns, but the very similar single-wire sender does not? Aren't they essentially the same technology sitting in a nearly identical environment?
Bill Coleman
2001 Saturn SC2 Auto (3/13-...) "Yellow"
1999 Saturn SL2 Auto (11/09-...) "White"
1995 Saturn SC1 Manual (9/08-...) "Gold"
1994 Saturn SL1 Auto (7/94-1/04) 144,000 miles "Green"
Add to aa4lr's Reputation
Rate the quality of this post and help aa4lr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aa4lr is offline   Reply With Quote
Old 11-11-2008, 06:02 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
They fail because of the design of the tip. Older one had a plastic tip while newer ones have a metal tip.
The other one probably fails just as much, it just doesnt cause drivability problems.
I guess you could always experiment and switch the two.
Mike
-1991 Turbo SL2.
-2000 SC2
Coolant Sensor and temp sender 1994 Saturn xtra2b S-Series Tech 2 05-05-2008 04:24 PM
coolant temp sensor or what??? RMracing125 S-Series Tech 2 02-19-2007 07:31 AM
Low coolant sensor poorboy S-Series Tech 4 06-29-2005 01:42 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
where is the coolant temp sensor buddyc S-Series Tech 2 08-06-2003 06:18 PM
