Old 06-26-2007, 01:08 PM   #1
BlueOgre
BlueOgre is on a distinguished road
Wrench 1999 SL2 Wont Start/Hard to Start in Hot Weather
Ok, this is a really annoying problem and i cant seem to put my finger on what is causing this. About 2 weeks ago, when the weather started getting hotter, my car started giving me a lot of problems starting. Its a 1999 Saturn SL2 w/DOHC. When i go to the car in the heat of the day, i hit the key, the car will crank/turn over, but it will not fire and start. Most times when the temperature is reasonable outside, but not always, if i let it sit with the ignition off for a few minutes, around 4 mins or so, i can go back to it, try again, and it'll generally start right up. However, if the temperature is in he 90s i can take me upwards of 30 mins cranking on and off to get it started. I thought perhaps i had a sensor going bad, so i plugged my OBDII scanner in and 99% of the time i get no errors, even when the car wont start. Twice, when it first started doing this, i got 2 errors, both reporting Cam Shaft Position Sensor, but i havent gotten any errors since. Anybody have any ideas?
Add to BlueOgre's Reputation
Rate the quality of this post and help BlueOgre reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BlueOgre is offline   Reply With Quote
Old 06-26-2007, 01:20 PM   #2
Default Re: 1999 SL2 Wont Start/Hard to Start in Hot Weather
Your car doesn't have a cam position sensor, so when you get codes related to it, it actually means something wrong with the ignition system (coil packs, spark plug wires, often it's just not grounded well).
The no-start you describe is a classic crank position sensor story. Two quick tests to try whenever you have a no-start:
* Poor-man's fuel test - Turn off the radio, blower, etc. and turn the key to RUN (but NOT to START). You should hear a "whirr" of an electric motor behind you, for about 3 seconds, followed by a "click" from the inside fuse box. That's the fuel pump priming. If you don't hear it, you'll have to start diagnosing the fuel pump relay, fuse, wiring, the pump itself, etc.
* Poor-man's spark test - Remove the #1 and #4 spark plug wires at the coil pack. Have someone turn the key to START for a few seconds while you observe under the hood. You should see a spark jumping between the exposed coil towers. If you don't, first suspect is the CPS.
Add to madpogue's Reputation
Old 06-26-2007, 01:24 PM   #3
2001sl1
2001sl1 is on a distinguished road
I want to thank you for that reply, because I am having the exact same problem with an 01 SL1.
Add to 2001sl1's Reputation
Rate the quality of this post and help 2001sl1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2001sl1 is offline   Reply With Quote
Old 06-26-2007, 11:52 PM   #4
auxmike
auxmike is on a distinguished road
auxmike's Avatar
I've owned both a '93 SL1 and now have a '97. They both seemed to need two trys to get the engine fired up hot. In my '97 I give 2 short bursts of starter knowing full well it won't start first try.
BTW: I keep a real nice spare Valeo OEM starter in my trunk...just in case....
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline   Reply With Quote
Old 06-27-2007, 12:55 AM   #5
Auxmike, your '97 probably suffers from the classic '97 fuel pump problem. Pump works fine, but fails to hold stored pressure when the car is parked. Rather than cranking (and prematurely wearing) the starter an extra time, try this: turn the key to RUN, and listen for the fuel pump to prime. Then turn it back to ACC, and to RUN again, and let it prime again. THEN, try to start the engine. If that works, then you've got the classic problem. Permanent fix is a new fuel pump; SPENDY! Best "workaround" is the "Wolfman method" (well, until he traded it in...) - turn the key to RUN, fasten seat belt as pump primes, turn the key to START.
Old 06-27-2007, 07:53 AM   #6
auxmike
auxmike's Avatar
I'll give it a shot. I hate sitting there waiting for the pump to prime though...
Patience, patience!
Old 06-27-2007, 08:35 AM   #7
BlueOgre
About a year ago i put a new fuel pump and filter on the car. When i turn the key on i hear the pump prime and kick off, yet still sometimes the car will not start. I've had to put 2 crankshaft position sensors on the car before, this was, i'd say, about 6 and 9 months ago. I didnt think that would be the problem again, but as that is the simplest thing to replace at this time, i'm going this morning to get another one, maybe 2, one to replace and one to keep handy. I'll keep you guys informed of what we find, maybe it'll help someone else with a similar/same problem.
Old 06-27-2007, 08:46 AM   #8
madpogue's post #2 is about as succinct as it can get; definitely perform his instructions first before buying another cps. It's a mystery if you have to go through more than one cps to correct the same problem repeating itself every few months.
Old 06-27-2007, 07:35 PM   #9
auxmike
auxmike's Avatar
Funny thing is my car starts right up first thing in the morining stone cold. But if you drive it, go into the mall for an hour, come out THEN you have to crank multiple times.
I just changed my fuel filter after 55k of use.
Old 06-28-2007, 06:36 AM   #10
BarnOwl
BarnOwl's Avatar
Fix the code and you'll probably fix your problem. This is about the best guide I've seen for diagnosing those codes.
Add to BarnOwl's Reputation
96 SL2 hot engine hard start. cvppjp S-Series Tech 4 04-14-2009 01:45 AM
97 SL2 hard to start when HOT mdcrabbie S-Series Tech 8 02-22-2009 02:25 AM
sl2 Hard to start when Hot mdcrabbie L-Series Tech 2 02-20-2009 10:38 PM
Car wont start! possible cold weather problem? northviper S-Series Tech 10 01-04-2008 10:57 AM
1997 SL2 hard to start when hot auxmike S-Series Tech 5 11-02-2003 01:43 PM
